- Mar 29, 2004
- UK
I have for sale a Precision 2.0m motorised dish setup with accessories.
The dish comes with an original Precision galvanised ground stand and triangular frame polar mount which are both in excellent condition.
Also included is a mobile platform that the dish is currently mounted on. The platform allows the setup to be moved to various locations on a property to maximise satellite line of sight opportunity.
In addition, as the platform is mobile it is not classed as a fixed structure.
The motorised setup can also be installed on the ground with suitable anchorage if the mobile platform is not used.
Other equipment included is:
Set of original Precision feed support arms
Original Precision Ku-Band feed and C120 waveguide interface
Set of adjustable stainless steel feed support arms custom made for the dish by forum member "Rima"
Stainless steel C-Band feed holder including split collar to accept 40mm neck Ku-Band LNB and a laser pointer holder to assist in peak alignment of the feed (all made by "Rima")
Geotrack 24" actuator (decent quality, better than the cheap Chinese stuff)
v-Box motor controller
Twin probe Universal Ku-Band LNB
Twin probe C-Band LNBF (3400-4200 MHz)
The setup is only for sale due to a need to make space for an alternative dish setup that requires a larger mobile platform.
I have attached some pictures below.
Asking Price
£800
Asking Price
£800
