Türksat-5a and new ku band??
s-band
Essex
I think the frequencies will be like this
Thanks for that.
They've been on 13428, 13508 and 13628 V and 13628H so far, plus 13650V (band edge).
The beacon on 13401V varies in power quite a lot.
@aloco Do you know what is likely to be carried on these channels?
aloco
turksat
ist
Thanks for that.
I don't know, but I don't think it's for watching TV.
Because you'll need extra lnb to watch TV
Ext ku 72mhz tp
@s-band
I've prepared the list based on the test information you provided.
s-band
Essex
Below threshold on my 1.2m dish but the 1st DVB that I've seen. They were only on for a couple of minutes.
13444V 2800 3/4 8PSK
13446V 1300 5/6 8PSK
The spectrum is at the point, on the waterfall, where 13628V at the same time as these DVB signals. There is also a dot at 13428 where that was on for a few seconds. The beacon, at 13401V, varies in level. (13560 is spurious)
Good spot - iv'e been concentrating on Ka this afternoon so missed the activity on 30.8 E
Will swap back over.
aloco
turksat
ist
12554H tested for the first time yesterday
s-band
Essex
Testing seen on 13428H, 13468V (new), 13508V, 13548V (new) & 13628V over the past hour (1140 UTC)
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
13548 V and 13588 V new here.
Any pictures yet or still the wavy line fest :cool:
... Along with yours was also 13587 V.
dx qwer
Rastatt/Germany
Linear horizontal scan now:
13428 H - catched this one here too
13468 H (new) - strong rain scan..
13508 H (new)
13548 H (new)
13587 H (new)
13628 H (new) - strong rain scan... :p
13650 H (new)
PS: Linear vertical also active now.
(editing new ones)
aloco
turksat
ist
13508 H (new)
13548 H (new)
13587 H (new)
13650 H (new)
(editing new ones)
Tests with the frequencies shown in the picture look the same
s-band
Essex
Here's a spectrogram covering about 15 minutes ending at 11:58 UTC
Signals are: 13468, 13508 & 13548 all V. The beacon power drops during tests and is just visible on 13401V.
s-band
Essex
They are testing with carriers and something 36MHz wide . I'm not sure if it is DVB but it looks more like Gaussian noise. The total power in the 36MHz signal is about the same as the carrier level.
If this is the level I'm going to get, I'll need 4-6dB more to receive DVB
Cheap Chinese junk LNB at hugely inflated rip off wad, or double the dish size?
I got stocks of both LNB's and dishes :eek:
just managed to grab this before it went - no info gathered.
