Promax Ranger - Owners/Users Topic
vma
Portugal
vma-satellite.blogspot.pt
RX: 3 motorized DiSEqC-1.2 dishes (100cm, 110cm, 120cm) + 7 regular dishes.
Main receiver: Vu+ Duo + many others & IRD
TX: Modulators for DVB-S/C/T + Dektec Modulators
Field Meter: Emitor, KWS, Kathrein, Unaohm, Promax, Spaun, Rover Instruments, ...
Portugal
I tried, but I cannot get a propper signal at 11699 H on 16.0E. Sorry... :(
Youv'e got them bloody crayons out again :p. Didn't realise the Neo went down to 2 MHz span - very useful. Our tatty old Rangers only go down to 10 MHz span,
@John
Not me with the crayons sir, it was Promax, they used the crayons in their video.
My Ranger Neo+ does not go down to 2 MHz span, it is 10 MHz, same as yours. It is the next model up in the range that can do the 2 MHz span.
However, from reading Vitor's feedback on editing some of the firmware update files I thought that it might be possible to get the non specified Ranger models to achieve a 2 MHz span.
It seems from the reply from Vitor in post 20 above that this might be possible?
vma
Portugal
Portugal
On a different note: the FW server seems to be down. Even NetUpdate 4 cannot find the server and issues an error.
vma
Portugal
Portugal
@moonbase: send me the current FW upgrade file. It should be a ZIP file and it should be in the NetUpdate4 folder on C:\.
It has been down for some time.
Promax are moving away from using the FW Server in favour of some other web method.
I contacted Promax to get a firmware update file which they sent by email.
It is a large file, 121mb when zipped, too large to upload to this forum.
I updated my meter with a USB stick containing the firmware update.
Sent you PM.
vma
Portugal
Portugal
I will look at it over the weekend. I am away from home at the moment.
It is the 16.0 East beacon at 11699.20 H.
I have attached a picture of the beacon below taken with a span of 2 MHz, other settings were Persistence = ON, Averaging = 7
The YouTube video is in the link below.
I need help, I am morphing into a wavy line merchant (bows head in shame).
Interesting video MB , not seen that before
Confession: Iv'e had the crayons out MB. ** 16east Beacon.
1.2 CM, North Nottinghamshire.
Looks like you enabled "Persistence".
That beacon peak at 11699.20 splits into 5 sub peaks in the Promax beacon video I linked to above.
They were using a Ranger model with 1 Mhz and 2 MHz span range options and a resolution bandwith of 40 KHz.
