Advice Needed TM 5402-M4 and driving dish - Positioner box 36v
Manikm909
Small'ish Dish Man
Kent, UK
Is anyone using the TM5402-M4 to drive their dish via a positioner box? Currently on my 1.2m CM i use an Octagon SF8008 which is connected to a V-BOX - works well. Im wondering what i could use without buying another Enigma2 (which i prefer over closed source ST:cool: to drive the 1.8m.
Any DiSEqC 1.2 compatible receiver will do. One that allows you to choose which position number is used for each satellite would be handy (though not vital).
manic01
TM5402 mk1/2/3/4 TM1500 TM Mini various TM Nano various TM600 TM F3/5 TM Twin etc etc TD110
GB
Ask Barney on SU
manic01
GB
Staff Note
Could you please be more explicit, so that all Members can understand?
Ask barney115 on Satuniverse forum or satpimps, manikm909 knows him well and Barney has various setups large small medium dishes etc using diseqc, positioner etc and also a TM5402 M4
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
Not sure what you’re trying to achieve but I’ve attempted something like this in the past. If you’re trying to achieve some form of system integration this DIY project from one of the board’s esteemed members @RimaNTSS might just be the way to go. There’s plenty of well qualified members here as you well know who would only be too glad to point you in the right direction on this topic Positioner for SAT antenna
There is also Dreambox1959's two year old thread with a very nice design and updates.
Home made diseqc positioner
Satspot
1.2m Triax dish
Ireland
There’s a few good DIY solutions out there using cheap (as in price) commercially available components. This one in particular looks very interesting and appears doable by the ordinary Joe Average without an engineering degree GitHub - AK-Homberger/Satellite-Dish-Positioner: An automatical satellite dish positioner with ESP8266 D1 Mini, compass and MPU.
Interesting use of the compass & gyroscope. Obviously the motor/mount design is no good for a 1.8m but for motorhome/caravan/barge use it's much cheaper than the off-the-shelf systems.
It would be interesting to see how accurate & consistent a compass/gyro based dish positioning system is.
Satspot
1.2m Triax dish
Ireland
Love the whole “thinking outside the box” DIY concept instead of throwing cash at a pre made solution and how these different hobbies can crossover nicely.
