neumoDVB
helmet
TBS 6903x - Inver.to Quad LNB
Belgium
A quick and positive update:
I managed to install the blindscan_kernel drivers and seem to have blindscan activated for my DVB-S card.
My solution was to downgrade the linux kernel on Fedora 34 from 5.15 to 5.11 with the command
sudo dnf downgrade kernel-headers kernel-devel
I then rebuilt everything and rebooted and it worked. Will now dig in to the settings and do some scanning.
Best regards,
Helmet
deeptho
Europe
Yes, for the kernel you really must follow the instructions exactly because of media_build related issues.
Hopefully later some solution can be found to make this simpler. For now it means that either you stick
with the exact kernel version described in the README, and/or you experiment with multiple versions of
media_build until you find one that works.
What can also help is to disable the devices that give compilation errors, as they are almost never related to the dvb drivers.
vasi54
SKYSTAR HD & PC QUAD CORE 2,66 GHZ
ROMANIA
I have installed driver for TBS6903x.
I try to install neumodvb but I have errors after cmake.
[root@fedora build]# cmake ..
-- The C compiler identification is GNU 11.2.1
-- The CXX compiler identification is GNU 11.2.1
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/lib64/ccache/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/lib64/ccache/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMake Error at /usr/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:218 (message):
Could NOT find Boost (missing: Boost_INCLUDE_DIR regex context
program_options) (Required is at least version "1.69")
Call Stack (most recent call first):
/usr/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:582 (_FPHSA_FAILURE_MESSAGE)
/usr/share/cmake/Modules/FindBoost.cmake:2208 (find_package_handle_standard_args)
CMakeLists.txt:29 (find_package)
-- Configuring incomplete, errors occurred!
See also "/root/neumodvb/build/CMakeFiles/CMakeOutput.log".
I use Fedora34 and cmake version 3.19.7
kernel-5.11.12-300.fc34.x86_64
kernel-5.15.11-100.fc34.x86_64
kernel-5.15.12-100.fc34.x86_64
kernel-devel-5.15.11-100.fc34.x86_64
kernel-devel-5.15.12-100.fc34.x86_64
deeptho
Europe
Please read the install section of the documentation and install what is missing...
and eventually install it:
Obtain BOOST: sudo dnf install boost-devel
go to the bootstrap file after you've downloaded:
./bootstrap.sh --prefix=/usr/
Build with b2:
./b2
Then install it:
sudo ./b2 install
Just thinking - you're not building from source with boost-devel, as with that the libraries will be placed in their respective folders
If instead you wish to build boost from source, choose a library from Boost C++ Libraries - Browse /boost at SourceForge.net ( I used 1.77.0)
then build from bootstrap as I described.
vasi54
ROMANIA
Many thanks for help.
I maked what you said and I obtained the graphic from neumodvb.
The blind scan is not tick yet in frontend options.
Test of neumoDVB on Linux Mint 20 Cinnamon Desktop
kernel 5.9.0-rc7-tbs+
TBS6903X using Inverto KaKu LNB
16E Ka 21612H
Spectrum scan of Band D TPs. Ignore shown frequencies - no Ka , only Ku and C. at present in neumoDVB. 21612H shown as 11114H.
@deeptho - will there be a possibility later of a LO fix for Ka bands, similar to that in e.g updateDVB's Custom LOF's?
vasi54
ROMANIA
1. I installed the driver for TBS6903x
[nicu@fedora ~]$ dmesg| grep frontend
5546b9ecae90c1b663f6694a83dd384904a425da media: dvb-frontends/stid135: option ts_nosync - TS FIFO Minimum latence mode.
[ 4.803545] TBSECP3 driver 0000:0a:00.0: DVB: registering adapter 0 frontend 0 (TurboSight TBS 6903x (Dual DVB-S/S2/S2X))...
[ 4.925409] TBSECP3 driver 0000:0a:00.0: DVB: registering adapter 1 frontend 0 (TurboSight TBS 6903x (Dual DVB-S/S2/S2X))...
2. Then I installed blindscan drivers without errors.
3. I Downloaded and compiled neumodvb without errors.
What is wrong because when I run neumodvb , in Lists -> Frontends the option blindscan is non selected?
Thanks.
Best regards
The way I do a blindscan in neumoDVB :-
Go to Lists ->LNB, choose your LNB, then Control-N to show the Spectrum screen.
Choose the polarisation and frequency range you require, then press Get Spectrum.
After the spectrum graph populates, you can then click on the Blindscan All button. After it scans the graph results, you then get a pop-up list of found frequencies.
Not certain where the list is stored, I didn't check (maybe later when I do another scan)
deeptho
Europe
Thanks.
Best regards
Well, vasi54,
you have to install the correct driver. It is all explained in the documentatun
deeptho
Europe
16E Ka 21612H
Llew, it is possible to add more lnb types and/or a custom lnb local oscillator frequency but it requires some programming.
I have been looking for a Ka-band lnb myself. Apart from the saorsat, there does not seem much for sale at a reasonable price. Tips on what/where to buy something for testing are welcome.
vasi54
ROMANIA
If you have deep pockets, the way into KA band reception is to splash out on one of the Norsat or SMW LNBs; then you need to source a feedhorn for your particular choice.
A few years ago some members here were able to obtain an Inverto combined KA/KU LNBF for a decent price through a quantity purchase. The KA band covers Band D, where several Sub-Saharan African channels are available on 16E and 7E (occasionally 4E, but not recently), probably feeds to the African diaspora in Europe.
Unfortunately Inverto don't seem to be interested any more in supplying the unit to anyone other than large companies (satellite internet providers probably).
Other than those expensive LNBs, sometimes the occasional cheaper (sub £50) KA LNB can be found on fleabay, in particular those used by the North American HughesNet broadcaster. These are usually for Band B, but one or two of us have been fortunate to get Band A and Band D versions.
Bear in mind though that some of these have large heavy transmitter units fixed to them, and sometimes the seller is reluctant to send the LNB separately (the cost of sending to Europe can be more than the LNB's price).
KA Band A LNBs will allow you to access the ITN NewsNet feed on Astra 1L 19E and its occasional OB feeds there, and the Italian Teleippica horseracing feed.
deeptho
Europe
deeptho
Europe
A few years ago some members here were able to obtain an Inverto combined KA/KU LNBF for a decent price through a quantity purchase. The KA band covers Band D, where several Sub-Saharan African channels are available on 16E and 9E, probably feeds to the African diaspora in Europe.
The D band seems most interesting and perhaps the Hughesnet (but without a transmitter - I do not want to much weight on the dish).
I have een checking feabay, without success. I guess the timing must e right. Anyway. it is not urgent.
@deeptho, is there any possibility in the future of adding a DVB-T/T2 facility to neumoDVB?
deeptho
Europe
DVBT is alrady inlcluded but probably not working due to lack of testing. There is nothing I can receive here at the moment.
A check of a multi-stream 5W.
@deeptho
I have an issue with DiSEqC porting with this program. I use a 4-port switch, with the 5W LNB on port 4 (3 using DiSEqC 1.0)
It always goes to port 1, so I think DiSEqC switching is not functioning. It's fine with updateDVB and Crazyscan on the same setup ( same PC, cable, switch).
deeptho
Europe
LLew,
I use diseqc here without any problem. Even the combination of diseqc1.0 and diseqc1.1 works.
So you may have misconfigured sometihng. Check your lnb configuration.
Ports are numbered starting from 0. So port 4 is diseqc1.0 value 0. Make sure that diseqc1.1 is turned off by setting it to -1
and that tune string has "C" in it.
Also make sure that you do not have more than 1 lnb cnfigured for 5.0W. It is fine to do that but then both configurations
must be correct.
The log files also contain the actual data sent to the swicth, so it is easy to verify.
Unrelated: Recently I also found an old bug in the drivers, which can cause problems on streams which use physical layer scrambling.
The symptom is that tuning may be slow or even fail in neumodvb. It is fixed in the latest drivers.
