14w new Russian transponder
Manikm909
Small'ish Dish Man
Kent, UK
omg he's got a Z t-shirt on!!!
MCelliotG
Thessaloniki, Greece
if you have to choose one between the Os mio 4K and the SF8008
which one would you take ?
I have explained their differences quite a few times:
Osmio is good for the average user which wants automated receptions, it auto blindscans PLS Multistreams, autofinds T2-MI, has no frozen image issue in zapping BUT it tunes a bit more slowly, has no internal HDD, cannot do very low SR (below 950), a little slower in general.
SF8008 is faster, tunes instantly, has very low SR, auto-finds T2-MI (not as efficiently as the OSmio) BUT cannot do PLS blindscan, has freezing image zapping (it's a HiSilicon chipset issue). If it could do PLS blindscan it would edge the OSmio imo.
Manikm909
Small'ish Dish Man
Kent, UK
Fisty McB
See my signature...
County Tyrone, N. Ireland
OK so tweaked the dish a little and managed to get lock on all 3, strange thing is to achieve this, had to nudge the dish to somewhere near 13.4W! The previously unlocked frequencies (11546 & 11564) now come in at around 9.2dB, while the 3rd on 11647 drops slightly from 14.7dB to 13.5dB. I thought maybe there's interference from 15W or 12.5W, but doesn't seem to be anything on those that would interfere. Very strange!
According to Flysat, there are data carriers at 15W on 11539 V & 11563 V. That would quite likely cause SNR issues with the two Russian transmissions at 14W on 11544 V & 11564 V in certain places depending on the RX area, and vice versa.
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
Nice spot. Did exactly the same and now all three TPs are locked and tuning.
11545 V 14180
11574 V 14585
11647 V 14181
Sat box TM5402 M4 Dish TD110
SatSearcher
West Yorkshire
It's possible the data signals on 15W are interfering, but having just done a quick scan on 15W, the data signal at 11539V only comes in at 4.5dB, I wouldn't have thought thats strong enough to cause interference.
Manikm909
Small'ish Dish Man
Kent, UK
Satspot
1.2m Triax dish
Ireland
mikeisyou
Feed Hunter
England
Does this 'Z' have a specific meaning? :confused
The Letter “V” represents the Russian Marines
The Letter “Z” represents units in the Eastern Military District
The Letter “Z” in a square represents the Southern Military District (Crimea)
The Letter “O” represents units from Belarus
The Letter “X” represents the forces of Ramzan Kadyrov, the Putin installed warlord of Russia’s Chechnya region.
The Letter “A” represents Russian Special Forces(SSO) like Spetznaz in its various operational units.
Adam792
Cheltenham
A nasty thought has just occurred to me on these, regarding them being reported as the Crimea versions.
I wouldn’t be surprised if they’re intended to be used to replace Ukraine’s DTT transmissions (which are also delivered to the transmitters by T2-MI over satellite), in areas captured by the Russian forces.
At least one medium wave transmitter in the east (810kHz) has apparently had its output of the Ukrainian Army FM station swapped for the Russian Vesti FM in the last few days as that’s happened.
astra19
98cm motorised technomate. 50e to 34.5w
Europe
I think you're on to something there.
Adam792
Cheltenham
It would also explain everything being FTA with no Gostcrypt, and the use of Ku Band rather than C Band (being able to use the existing equipment at Ukrainian TX sites).
14°W is probably the closest Russian sat to 9°E which Zeonbud Ukraine uses too.
Manikm909
Small'ish Dish Man
Kent, UK
their tv tower has been attacked!
mike1
Non-28.2° Sat Specialist
Yorkshire Television
Triax 64cm triax ( Darkmotor ) Inverto Black Ultra.
T55 - 28E/19E/13E/1.9E
Mutant AX 51 Open PLi
GT Media V7SX
Hi
zorbua
Which Enigma 2 receiver are you using?
Can you provide a config backup file?
All European beam transponders have been switched off @ 14 west.
Adam792
Cheltenham
They seem to have all moved across to 53°E now.
12575H 14182
12592H 14182
12610H 16410
All still FTA and listed as the Crimea versions. Home - FlySat Satellite Chart
mike1
GT Media V7SX
14w working here in Yorkshire via 60cm dish.
Still can pick up 1tv , 24 , match , ntv on 11647v T2mi 14w
Dggrr
VU + Zero, Triax TD88, Technomate TM2600 (Plus CM 1.2 in bits behind the shed)
SE
All 3 transponders working for me in West Herts, 80cm dish 07:55am, SF8008
