Rai 4K
dankargo
Brentwood, UK
90cm Motorised
Brentwood
Hi all,
I'm looking to gain access to this channel and after some research, it appears my best bet is through a Tivusat card. I don't really have much experience in cards or CAM, have mainly gone down the FTA route but would like to know if it's possible to get this card working on an Octagon SF8008 receiver? I have a slot for a CA card but not a cam.
Adam792
Cheltenham
Apparently the Gold (HD) version of the Tivùsat card will work using OSCam, which is how you’d get it working on the SF8008. This one supposedly allows Rai 4k to decode but not the other 4k channels.
The newer 4k black card will not work in OSCam and has to be used with the supplied CI+ module (CAM) in a compatible TV or receiver.
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18", Superjack 3618, Moteck Vbox2, IBU PLL Single, DM900 RC20 UHD 4K" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single, Edision OS Mini 4k" "Tivusat Gold Card & Cam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
Hi, i have the gold hd card, and can confirm rai 4k works with oscam. which other channels are you referring to?
Adam792
Cheltenham
Museum, TravelXP and MyZen are the other three UHD channels that are apparently in the package but don’t clear in OSCam.
stel883_
Vátika, Greece
Hi again, thanks for replying. I don't really watch those channels, so i hadn't noticed. I do have the CI+ module and will do a test!
dankargo
Brentwood, UK
90cm Motorised
Brentwood
Many thanks both :) I will go on the hunt for a gold Tivusat card
cirio70
Laminas 180 - Fracarro UX-TW-LTE(PLL) - C Band - TBS6903 - Octagon SF 8008 -Zgemma H92S
Lombardy - Italy
Be sure the card have CAID "183E" and not "183D", otherwise it will not clear RAI4K.
dendrite
Triax 1.1 on TM2600 motor Tm5402m4 / vuplus
Rotherham
Hi all,
At the moment the Technomate 5402 works with the Tivu cam. In the recent past, Canal Digitaal and Polsat NC+ Poland cams also worked on the 5402, but there have been changes, which have rendered it incompatible. So, I think unless you're using a ci+ cam slot receiver, like the Technisat, it would not be a good bet, to use anything but a proper Tivusat box, in case they change any parameters.
Andrew - Satellite TV Europe
marcouk
Vu+ Uno 4K SE, 1.2M Laminas motorised dish. Primesat 1.3 m dish
Hull UK
Gold card available here (pre-activated)
https://www.pulsat.com/products/Tivusat-Official-Italian-HD-TV-Viewing-Card.html
