47,7° East Eutelsat Quantum
dreamsat
germany
my scan with AOL service
Locked both transponders:12370 V & 12372 V. Couldn't find 12105 H. Probably left?
New test carrier 11325 V
Still not much signals from this satellite, just 12372V here.
dreamsat
germany
at 3.7 m I can receive these two transponders
Correct dreamsat, TBS5927 often skips FEC 1/2 during blindscan, locked manually with 4.0 dB.
anto@
italy
my signal
deeptho
Europe
Below is a scan with neumoDVB and tbs6909x. None of the signals is lockable. The rest of the spectrum (not shown) shows transponders
from 49.0E. The peaks below are the only ones which are not stronger when I move the dish to 49E.
This is with a laminas 1.2m motorized dish in Belgium.
47.7E_11790 H,132994,fec-unkown,. I locked it on blindscan with tbs6903x but manually failed, probably because of a weak signal.
Maybe someone here can try(@dreamsat?)
I finally managed to locked the signal manually and see the parameters of this transponder.
It seems that only with 100000 Ks/s it can lock although it's higher (1321997 Ks/s). The auto scan shows this symbol rate every time.
Maybe someone will confirm or deny this parameter!?
dreamsat
germany
I will try it today with 2.20m. :Y
I can see the signal here 17Km North of Nottingham UK but too weak to lock.
Ku pll lnb not at dish focus - side saddle next to the Cband feed on my 2.2mtr PF so probably working similar to around a 2mtr at focus
dreamsat
germany
@ satesco
I can see the transponder and the 11892 is fine. A lock is not possible. What version of CrazyScan and what Stream Reader file are you using?
best regards
dreamsat
germany
it works with CrazyScan 1.0.2.171. I can enter 10000 and the lock is there. Unfortunately, I was unsuccessful in the blind scan. Can these parameters still be confirmed.
@dreamsat,
It doesn't matter what version of TSReader you use, but it's good to use recent versions of Crazyscan. The first time I used CS ...171 and it found this transponder with a 6903x card.
Now I used the 6909X card with Crazyscan version 1.0.2.160 and it found and locked auto and manual 11790 H.
Crazyscan doesn't know how to read manual symbol rates over 100000 Ks/s, that's why it's better not to add the last digit of the symbol rate, as in the picture.
I think 11790 H is also transmitted with s2x extension, that's why it doesn't show other parameters. It has RollOff:0.10
Regards:Y
EnoSat
enosat.euweb.cz
Slovakia
dreamsat,
but bitrate wrong - for SR-100000 must be 300 Mbit/s
dreamsat
germany
you are a joker. the bit rate varies greatly up to almost 300 Mbit. It's difficult to get the picture right. Please try it yourself and post your results in the forum. I don't think it's good if you only ever get clever tips without the person himself being able to produce any insights.
dreamsat
germany
i confirm with satesco:Y
For those who have the 6903x/6909x card and want to lock the symbol rate of the 132997 Ks/s at 47.7East, I provide this video tutorial.
Who knows, maybe it will help them :)
