TM5402 M4-7 day EPG has arrived
Manikm909
Small'ish Dish Man
Kent, UK
rodscha
Been somewhat ill lately,nothing too bad. Want to download the update now,my question is!
do I need a factory reset after I download the latest TM update?
or will it work anyway?
I m asking because I have spent time arranging lists already....
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
Just backup your channel settings first before you apply the upgrade. You shouldn’t need it but it’s always advisable to do a backup. No need for any factory reset. Once the upgrade completes you’re M4 will reboot and you’re good to go.
manic01
TM5402 mk1/2/3/4 TM1500 TM Mini various TM Nano various TM600 TM F3/5 TM Twin etc etc TD110
GB
New patch in DL centre
rodscha
I backed up my channel list.
and upgraded ,worked fine!!
will try fav lists now!
Satspot
1.2m Triax dish
Ireland
manic01
GB
is that new patch important?
If you like Biss it may enhance your stb
http://downloadtmsw.com/bbs/reply.php?board=tm5402m4&num=14
Satspot
1.2m Triax dish
Ireland
thank you! where is DL centre?
Just to point out to you once again that the “patch” referred to in the above link is not official Technomate firmware but supplied by some 3rd party operator. If anything does go wrong either installing it or using it Technomate or their agents will want to know nothing about it. Basically you’re on your own. This should have been clearly pointed out to you in advance.
rodscha
thank you I now clearly agree.
manic01
GB
New official SW
23/04/23: Fixed time (can choose Network or Satellite time).
Here
Satspot
1.2m Triax dish
Ireland
Just proves that after all this time TM are still providing support for this box unlike most of the Asian junk boxes that last a year or less and the manufacturers abandon them.
For how long though? They dropped support for some of their older boxes that are still on sale far too quickly.
