7°E feeds
dankargo
Brentwood, UK
90cm Motorised
Brentwood
Boris Johnson Confidence Vote Result
11043 H 4937
FTA
ViaHussun
150 cm offset Gibertini antenna
Inverto Premium Twin LNB
TBS 5520SE TV Card
Bursa , TURKEY
7E 10982 H 14400 8PSK 4:2:2
Biss :Y
7East Ku
10.959H. 8570. DVBS2X, 16APSK, 8/15, ID: Fi16GNVE. FTA.
I found something on 07.0 East at around 12709H using a Promax Ranger meter but Crazy Scan, EBSPro, IQMonitor and an Octagon SF8008 all fail to register it.
There are a couple of screen grabs below from the Promax and IQMonitor.
I suppose it could be a bunch of closely stacked narrow bandwidth data streams and IQMonitor has better resolution on it compared to the Promax?
Any suggestions?
12708 H,11428,23/36,(S2X)/16APSK,0.05-Data
I found something on 07.0 East at around 10974V-10975V using a Promax Ranger meter but Crazy Scan, IQmonitor and an Octagon SF8008 (S2X capable) all fail to register it.
There are several screen grabs attached below from the Promax, IQmonitor and CrazyScan.
There are two similar but narrower bandwidth frequencies immediately to the right that also fail to register in IQmonitor, CrazyScan and the Octagon SF8008.
I am unable to check Flysat at the moment to see if anything is reported at those frequencies.
Any suggestions
20221028_07.0E_10975V_Promax.jpg 20221028_07.0E_10975V_IQmonitor.jpg 20221028_07.0E_10975V_CrazyScan.jpg
Any suggestions
View attachment 145679 View attachment 145680 View attachment 145681
10.973 V & 10.974V are listed as having feeds on Flysat - i'll spin the dish and take a look
@John
Thank you.
I just did a quick check with the NS2000, the frequency of 10973V is syncing and locking using NS3 mode.
I have not yet checked the pair of adjacent narrower bandwidth frequencies located between 10973V and 11011V.
I have posted an NS2000 demodulator screenshot of the 10973V frequency in the Novelsat topic.
@John
Thank you.
I just did a quick check with the NS2000 and 10973V is syncing and locking with NS3 mode.
I have posted an NS2000 demodulator screengrab of the 10973V frequency in the Novelsat topic.
Yes, the Promax grab from mine as well shows the typical physical shape of a NS3 type signal. My GTM Combo doesn't capture it either.
@John
Thank you.
Along with 10973 V, two other feeds (IMG) transponders are coded.
7East Ka FEED.
ViaHussun
TBS 5520SE TV Card
Bursa , TURKEY
7E 11603 V 15000 8PSK 4:2:0
FTA :Y
12655 H is active with a UHD promo, SR is 2475 FEC 2/3. Legend Alforat HD2 Neither the Octagon nor the GTMedia Combo are clearing the video, but the latter is having a good go.20230206_120459[1].jpg
Odd. the 8008 believes it is on a slightly different frequency and in SD.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
UHD with a SR of 2475 / FEC of 2/3? Goodluck with that
deeptho
Europe
Comes in well with neumoDVB:
7° East Ka Feed
21.663 H. - upcoming football feed. fta.
