Roger Waters - This Is Not A Drill - 25th MAY - 19:00 BST - 20:00 CEST - 18:00 UTC
Spc..
TeVii S2 Tuners, 138cm Gibertini + 100cm backup dish
Slovenia
It will be uplinked on 0.8°W with dolby digital audio - 5.1 AC3 @ 640kbit/s.
I am assuming these parameters:
Satellite: 0.8°W
Frequency: 11494 MHz
Polarization: V
Symbol Rate: 14500
Please try to record this show it will be amazing.
I will also be recording it, but if i get bad weather i might loose signal :(
Note:
As cinemas do not have BISS support, this event will likely be uplinked as FTA uplink.
UPLINK should start at:
CEST: 18:45
BST: 17:45
UTC: 16:45
Spc..
Slovenia
More info:
Spc..
Slovenia
Frequency could also change to exactly:
0.8°W 11508 V 14500 + 14MHz
Spc..
Slovenia
Same as Roger Waters uplink, right now test:
0.8°W | Vertical
11481.553 Mhz, 14400 KS, DVB-S2/QPSK, 3/4, 13.0 dB
You can now test and fine tune sat dish for roger waters concert with help of this frequency.
Spc..
Slovenia
Frequency down.
rodscha
is that receivable on an "ordinary" receiver? is the +14Mhz an issue?
More info:
In case
tompouce
1.2 M Channel Master motorized+ Gibertini 150 C-band fixed + TBS 5925/6983+ Octagon SF4008
Belgium
I read some strange comments... normally, always the same frequency/parameters for the tests and the live transmission ! the first tests were on 11504 V (and it's a 18 Mhz bandwith).
tompouce
Belgium
Note:
CEST: 18:45
BST: 17:45
UTC: 16:45
Comme d’habitude, jamais besoin d’une clé biss pour ces Tx. Normalement, les récepteurs originaux (IDC) étaient prêts avec les codes de clé biss mais l’utilisation de récepteurs commerciaux a décidé d’une autre façon !!
tompouce
Belgium
As usual, never need a biss key for these Tx. Normally, the original receivers (IDC) were ready with the biss key codes but the use of commercial receivers decided another way!!
The 4:2:2 format is perhaps a good solution but no hopes with the latest boxes in the cinemas.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
I doubt the people who would pay to see it in the cinema vs people who have the hardware to watch it for free at home overlap much to really have it be an issue.
Spc..
Slovenia
Yea i meant 18MHz, not 14MHz
I typed too quickly and mistyped 18MHz :D
Spc..
Slovenia
Some people do not know this, but yea everyone who knows can just watch it at home.
It's always FTA 4:2:0 as cinemas do not have any BISS hardware.
Spc..
Slovenia
Very strong signal today:
11495.041 Mhz, 14499 KS, DVB-S2/QPSK, 3/4, 15.0 dB
tompouce
Belgium
Yes it's always free.
They forget to protect the Tx (it's the reason we speak about this) but originally all boxes used (IDC Superflex Duo from International Datacasting) have an internal BISS hardware !
SkyWatcher
Comag SL65, Azbox Premium HD+, Azbox Mini Me, Techno mate Tm3000 D, Golden V8
London
Lexzie
TBS 5925 USB-tuner
The Netherlands
On 7°E some tests were received today with the IDENT "Roger Waters-MAIN (EMG Connectivity)"
BISS encrypted.
7.0°E 12684, H, 14500 DVB-S2 QPSK FEC 3/4 Roger Waters-MAIN (EMG Connectivity) 4:2:0
Spc..
Slovenia
BISS encrypted.
how was the bitrate ?
higher than on 0.8°W ?
Was dolby-e included ? or was it standard dolby digital ? / stereo ?
Also EMG is from nethelands.
Spc..
Slovenia
Backup is on 23.5°E from http://satelliweb.com
Signalé par gir le 23/05/2023 à 17:11
Astra 3B (23.5°E)
Fréquence: 11506 - Pol: H - SR: 14500 - FEC: 3/4
Catégorie: Concert
Transmis en: MPEG-4 crypté
ℹId : Roger Waters Backup
Lexzie
TBS 5925 USB-tuner
The Netherlands
Bitrate
23.5E
7E
