Eutelsat Hot Bird 13G
HOTBIRD 13G
NORAD ID:54225
LOCAL TIME:12:31:04
UTC:11:31:04
LATITUDE:0.01
LONGITUDE:13.01
ALTITUDE [km]:35788.84
ALTITUDE [mi]:22238.15
SPEED [km/s]:3.07
SPEED [mi/s]:1.91
AZIMUTH:163.4 SSE
ELEVATION:+29.8
RIGHT ASCENSION:04h 46m 25s
DECLINATION:-08° 25' 22''
Local Sidereal Time:03h 49m 39s
The satellite is in day light​
SATELLITE PERIOD:1434m
Paolo71
Gibertini 100cm, STAB HH120, Inverto BU 0.2dB, Laminas 120, Moteck SG2100A, Inverto Premium 0.2dB.
TBS 5925, Edision OsMio 4K plus, AZbox Premium HD+, pc AMD FX8350 ram 32Gb. IQMonitor Pro, EBS Pro, Crazyscan, DvbDream, VLC and PotPlayer.
Monterotondo (Rome), Italy
Hi all, I analyzed some beacons from 13°E and here it is..... on the right, HB 13G !!!
I hope it's useful to understand something...........
it mean 13b replace to 13g transponder
@Paolo71 the beacons/telemetry are in that order
The signal on 11702.81 in circular polarity (RHCP) comes from the satellite Hylas 1 at 13.7°E in inclined orbit.
These are the beacons/telemetry on 12500-12506 MHz...
Rutep
Hotbird 13 east
Iceland
What is happening, I cannot reach anything now. The weather is not that bad. Have Hotbird channels.
I guess the LNB is kaput. What is the best equipment to replace it ?
toortoor
AMD 2.71GH,DM-500-S,125CM FIBER DISH,BOX 09876616606,ZENEGA 1025.
MUKTSAR(PUNJAB)
New tp add
10854 H 31427...
Rutep
Hotbird 13 east
Iceland
I mean is one brand of LNB better than others ?
Maybe a raven has taken a part of the cable to it....
Paolo71
Hi Marcus_21, I thought that the second beacon on the left was HB 13E as in Satbeams gives the same data : 11702.8H
Satellite Name: Eutelsat Hot Bird 13E (HB13E, Eutelsat 9A, E9A, Eurobird 9A, Hot Bird 7A, Hotbird 7A)
Status: active
Position: 13° E (13° E)
NORAD: 28946
Cospar number: 2006-007B
Operator: Eutelsat Communications S.A.
Launch date: 11-Mar-2006
Launch site: Guiana Space Center
Launch vehicle: Ariane 5 ECA
Launch mass (kg): 4100
Dry mass (kg): 1740
Manufacturer: Thales Group
Model (bus): Spacebus-3000B3
Orbit: GEO
Expected lifetime: 15 yrs.
Call sign:
Beacon(s):
11702.8H, 11704H, 12500H
Details:
38 Ku-band transponders to provide video and Internet services to Europe.
Charts: list
New tp add
10854 H 31427...
The txp 10853 H, has been active since May 2... it is not a new activation.
Contains only data, with different modcodes.
Status: active
NORAD: 28946
Dry mass (kg): 1740
Orbit: GEO
Call sign:
Beacon(s):
Details:
Charts: list
Hotbird 13E can switch on-station telemetry between two frequencies (11702,80 H and 11704,00 H), but they cannot be turned on at the same time. LEOP/Emergency telemetry is S-band (during LEOP operations it was 2265,188 circular polarity), then has a on-station beacon (no telemetry signals) 12500,00 H (not currently in use, otherwise it overlaps with that of the Hotbird 13C).
toortoor
MUKTSAR(PUNJAB)
One More tp available here bro...
toortoor
MUKTSAR(PUNJAB)
Hayank
13E, 9E, 16E
India
Hotbird new satellite 13g & 13 F will cover the Indian region or not
toortoor
MUKTSAR(PUNJAB)
Minimum 360cm or more large antenna ......
Can get only 10-15 TP,s Only....
Rutep
Hotbird 13 east
Iceland
I get notifications of new answers. I have clicked on that option NOT to get them.
