Eutelsat 13C now called (Eutelsat 12 West G @ 12.5° W)
These transponders also appear to work with the S2X extension(?). I infer this from the RollOff of 0.05 to 10843 V and 10872 V.
anto@
italy
there are 2 carriers at 12519 and 12562 V
12659H
10855 H
10836 V
10873 V
12659H
Yes, I saw them but couldn't lock them. :unsure
I don't want to dwell too much on the S2X extension of the three muxes to 12.5W. But tests with neumoDVB seem to confirm that this mode is also used.
anto@
italy
there is no interference it is 12.5 west with a 180 disc the frequencies of nearby satellites are not noticeable
anto@
italy
those are very strange signs
What fraquency use it
Here is what the signal looks like with the 6983 card.
I'm unsure if the mux found and parameters by IQmonitor are valid.
The signal should be checked in the next few days.
I contacted lyngsat & flysat re the correct position of Hotbird 3C,
lyngsat have now updated their site:-
and n2yo still wrong position 18w
anto@
italy
new tp 11257 11298 H 31429
3 tp right low signal
Thanks @anto@; there's another one activated at 11294 H, 31422, 1/2; both appear to be generic streams.
Around 12544V, what type of transponder would give a waterfall like this? It like the bandwidth is constantly changing :confused
Something similar between 12504 to 12520V. The spike in the spectrum is a clock spur from the SDR.
EnoSat
enosat.euweb.cz
Slovakia
Maybe used for TDM/TDMA VSAT Hub
