tasoss
- 6903,6903x,6909x 6908 etc. Dishes on various satellites(7east,39east,30w,8w etc) Windows & Linux for blind scanning and Linux for channel scanning.
- Greece
@deeptho
Another problem that i face is using scan-s2 ( GitHub - crazycat69/scan-s2 ).
This program used to work before the latest update of the drivers.
I was scanning transponders (getting from blind scanning) in order to get channels etc.
With the latest drivers it doesn't work.
You can reproduce it using something like :[Sat Feb 1 19:45:53 2025] ------------[ cut here ]------------
[Sat Feb 1 19:45:53 2025] kernel BUG at /home/tasoss/dvb/neumo/neumo_media_build/v4l/dvb_demux.c:1087!
[Sat Feb 1 19:45:53 2025] Oops: invalid opcode: 0000 [#1] PREEMPT SMP NOPTI
[Sat Feb 1 19:45:53 2025] CPU: 6 UID: 1000 PID: 2454 Comm: scan-s2 Tainted: G OE 6.12.11 #1
[Sat Feb 1 19:45:53 2025] Tainted: [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[Sat Feb 1 19:45:53 2025] Hardware name: ASUS System Product Name/PRIME B660M-K D4, BIOS 3601 10/12/2024
[Sat Feb 1 19:45:53 2025] RIP: 0010:dvb_demux_output_feed_add+0x193/0x1b0 [dvb_core]
[Sat Feb 1 19:45:53 2025] Code: 63 c0 48 c7 c7 e8 0d 64 c0 44 0f b7 83 30 11 00 00 e8 91 8b b8 d4 e9 2f ff ff ff be 01 00 00 00 e8 52 74 24 d5 e9 16 ff ff ff <0f> 0b be 02 00 00 00 e8 41 74 24 d5 e9 05 ff ff ff 66 66 2e 0f 1f
[Sat Feb 1 19:45:53 2025] RSP: 0018:ffffb1cecaffb9a8 EFLAGS: 00010246
[Sat Feb 1 19:45:53 2025] RAX: ffffb1cec8c41000 RBX: ffff8e4c9f080b38 RCX: 0000000000000000
[Sat Feb 1 19:45:53 2025] RDX: ffffb1cec8c41000 RSI: ffffb1cec87a4008 RDI: ffffb1cec8c41000
[Sat Feb 1 19:45:53 2025] RBP: ffffb1cecaffb9c8 R08: 0000000000000000 R09: 0000000000000000
[Sat Feb 1 19:45:53 2025] R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
[Sat Feb 1 19:45:53 2025] R13: 0000000000000000 R14: ffffffffc060dce0 R15: ffff8e4c9f080dc8
[Sat Feb 1 19:45:53 2025] FS: 000072349d4a9740(0000) GS:ffff8e4fef500000(0000) knlGS:0000000000000000
[Sat Feb 1 19:45:53 2025] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[Sat Feb 1 19:45:53 2025] CR2: 000072349d2eca20 CR3: 0000000106dc6000 CR4: 0000000000f52ef0
[Sat Feb 1 19:45:53 2025] PKRU: 55555554
[Sat Feb 1 19:45:53 2025] Call Trace:
[Sat Feb 1 19:45:53 2025] <TASK>
[Sat Feb 1 19:45:53 2025] ? show_regs+0x6c/0x80
[Sat Feb 1 19:45:53 2025] ? die+0x37/0xa0
[Sat Feb 1 19:45:53 2025] ? do_trap+0xda/0xf0
[Sat Feb 1 19:45:53 2025] ? do_error_trap+0x71/0xb0
[Sat Feb 1 19:45:53 2025] ? dvb_demux_output_feed_add+0x193/0x1b0 [dvb_core]
[Sat Feb 1 19:45:53 2025] ? exc_invalid_op+0x52/0x80
[Sat Feb 1 19:45:53 2025] ? asm_exc_invalid_op+0x1b/0x20
[Sat Feb 1 19:45:53 2025] ? __pfx_dvb_dmxdev_section_callback+0x10/0x10 [dvb_core]
[Sat Feb 1 19:45:53 2025] dvbdmx_allocate_section_feed+0x179/0x1f0 [dvb_core]
[Sat Feb 1 19:45:53 2025] dvb_dmxdev_filter_start+0x48d/0x540 [dvb_core]
[Sat Feb 1 19:45:53 2025] dvb_demux_do_ioctl+0x1b7/0x940 [dvb_core]
[Sat Feb 1 19:45:53 2025] ? __check_object_size+0x6d/0x300
[Sat Feb 1 19:45:53 2025] dvb_usercopy+0x6a/0x1d0 [dvb_core]
[Sat Feb 1 19:45:53 2025] ? __pfx_dvb_demux_do_ioctl+0x10/0x10 [dvb_core]
[Sat Feb 1 19:45:53 2025] dvb_demux_ioctl+0x15/0x30 [dvb_core]
[Sat Feb 1 19:45:53 2025] __x64_sys_ioctl+0x9d/0xe0
[Sat Feb 1 19:45:53 2025] x64_sys_call+0x11ad/0x25f0
[Sat Feb 1 19:45:53 2025] do_syscall_64+0x7e/0x170
[Sat Feb 1 19:45:53 2025] ? mntput+0x24/0x50
[Sat Feb 1 19:45:53 2025] ? terminate_walk+0x65/0x100
[Sat Feb 1 19:45:53 2025] ? path_openat+0x4dd/0x1350
[Sat Feb 1 19:45:53 2025] ? do_filp_open+0xc0/0x170
[Sat Feb 1 19:45:53 2025] ? putname+0x5b/0x80
[Sat Feb 1 19:45:53 2025] ? do_sys_openat2+0x9f/0xe0
[Sat Feb 1 19:45:53 2025] ? syscall_exit_to_user_mode+0x4e/0x260
[Sat Feb 1 19:45:53 2025] ? do_syscall_64+0x8a/0x170
[Sat Feb 1 19:45:53 2025] ? ksys_write+0x73/0x100
[Sat Feb 1 19:45:53 2025] ? irqentry_exit+0x43/0x50
[Sat Feb 1 19:45:53 2025] ? sysvec_apic_timer_interrupt+0x57/0xc0
[Sat Feb 1 19:45:53 2025] entry_SYSCALL_64_after_hwframe+0x71/0x79
[Sat Feb 1 19:45:53 2025] RIP: 0033:0x72349d324ded
[Sat Feb 1 19:45:53 2025] Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
[Sat Feb 1 19:45:53 2025] RSP: 002b:00007ffe503fe640 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[Sat Feb 1 19:45:53 2025] RAX: ffffffffffffffda RBX: 0000000000002968 RCX: 000072349d324ded
[Sat Feb 1 19:45:53 2025] RDX: 00007ffe503fe6b0 RSI: 00000000403c6f2b RDI: 0000000000000004
[Sat Feb 1 19:45:53 2025] RBP: 00007ffe503fe690 R08: 00000000ffffffff R09: 0000000000000001
[Sat Feb 1 19:45:53 2025] R10: 0000000000000000 R11: 0000000000000246 R12: 000000000000000d
[Sat Feb 1 19:45:53 2025] R13: 0000000000000000 R14: 00005f1b08fd2c18 R15: 000072349d507000
[Sat Feb 1 19:45:53 2025] </TASK>
[Sat Feb 1 19:45:53 2025] Modules linked in: qrtr xt_tcpudp nft_compat nf_tables libcrc32c binfmt_misc nls_iso8859_1 xe drm_ttm_helper gpu_sched drm_suballoc_helper drm_gpuvm drm_exec intel_rapl_msr intel_rapl_common intel_uncore_frequency intel_uncore_frequency_common intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel stid135(OE) i915 kvm crct10dif_pclmul cmdlinepart crc32_pclmul polyval_clmulni input_leds polyval_generic spi_nor ghash_clmulni_intel joydev eeepc_wmi mei_hdcp mei_pxp sha256_ssse3 asus_wmi sha1_ssse3 mtd sparse_keymap ee1004 aesni_intel platform_profile crypto_simd i2c_algo_bit wmi_bmof cryptd drm_buddy video tbsecp3(OE) rapl intel_cstate tas2101(OE) ttm mei_me i2c_i801 spi_intel_pci dvb_core(OE) drm_display_helper spi_intel mei i2c_smbus intel_pmc_core intel_vsec pmt_telemetry acpi_pad wmi pmt_class acpi_tad sch_fq_codel msr parport_pc ppdev lp parport efi_pstore nfnetlink dmi_sysfs ip_tables x_tables autofs4 hid_generic usbhid uas hid usb_storage nvme r8169 intel_lpss_pci nvme_core ahci
[Sat Feb 1 19:45:53 2025] intel_lpss realtek libahci idma64 vmd nvme_auth pinctrl_alderlake
[Sat Feb 1 19:45:53 2025] ---[ end trace 0000000000000000 ]---
-a2 is the adapter usedecho "S2 10720739 H 29998872 3/5 AUTO 8PSK " | scan-s2 -I 50 -o vdr -t 1 -lUNIVERSAL -U -a2 -x -2 /dev/stdin
