ched999uk
- Feb 7, 2014
- Age
- 54
- zone 1 sky type dish with quad lnb @28.2e, zone 2 sky dish with octo lnb @ 19.2e and Humax Foxsat HDR
- Sunny Blackpool
I apologise in advance for such a basic question.
Read lots of great advice here, thanks.
Setup new zone 2 dish to 19.2e great signal and quality, I am very pleased, thanks.
I have a multi lnb holder and additional lnb (quad). So I had a quick try to get 13e.
I couldn't get a signal let alone quality. I was very pleased to get 19.2e working so decided not to push my luck today
So standing in front of the dish pointing to 19.2e which side should the 13e lnb be, I think it's on right?
I tried using this equation:
d(distance between centre of lnbs)= L(focal length, dish to lnb 330mm) x tan(a)(19.2-13 =6.2) to find distance between lnb centres.
This works out at 35.8mm between lnb centers. The feed horns on my lnbs are 60mm so there is no way I can get the centres 35.8 mm away from each other.
Am I doing something wrong or do I need different lnbs?
Thanks for any help.
