21.5E (Eutelsat 21B)
Piltdownpaul
No.1 Spike Milligan Fan
Around 50% here.
Archived-1
Persona non grata
uk
Hi, is anyone getting the mbc channels 10731 V 45000 please, I used to be able to lock them when conditions were good, but I haven't had a sniff at them for a long while now :(.
Piltdownpaul
I cant get anthing from 10731. Its been months since i had anything from that freq.
Archived-1
Persona non grata
uk
They changed the beam I think paul when the MBC channels fired up ?, and they were a hard catch on the 1.2, but I could get them now and then, they went FTA a few weeks back, but I cant get a sniff at them now,
A great night for dxing here tonight, but I am getting nothing, along with all the other nice evenings i've tried :(.
Piltdownpaul
Cloudy here tonight, the weekend might be a better proposition.
2night
vantage hd 8000s
120 cm dish
windows 7
friesland (nl)
hoi,
is now multi stream channel transponder.
you need a computer tv card to see
Archived-1
Persona non grata
uk
hoi,
Thanks 2night, that explains it then, I will have to set my card backup at some point, i am missing out on lots :(.
far78
1m Orbital and Supreme Intelligent Dark Motor, TBS 6925 and Tevii S464 PC cards, TM5402 M1
York, North Yorkshire
Beware though - I think you really need a TBS 6925 for multi stream transponders - normal cards like my old TBS 8920 don't work :(
digi247
NW
see sig
You only need something like the TBS6925 to view these Multistream channels but a standard receiver should still pick up the signal, I have a funny feeling that these channels have swapped Footprint
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Agree with you, although I do not have any multistream card I cannot even see a signal.
MBrincat
1.2m motorized dish, VBOXII positioner, Titanium LNB 0.2dbs,
Dreambox 800HD
Malta
I do not have any tv card and all MBC channels on 10731 V 45000 2/3 (DVB-S2 8PSK) on 21.6E open without any problem. Free to air...
Interesting.
Maybe the high SR is a problem >>> I'm pretty sure my Skybox F3 can't cope with 40000+ (I did once try it with the BBC Feeds on 27.5W).
But will have a look .........................
Edit: Nada. Zilch. Not a sniff.
Well, I am getting something on the Fibo, but no lock...
Archived-1
Persona non grata
uk
Thanks all :), the old mux at 10731 was very easy to catch for me on a 1mtr dish, so they must have changed footprint as digi says,
My pci card will open the multi streams but it looks like this is not the case (PCIe-TV SkyStar 2 eXpress HD) yes looks like you have something there CJ, I will keep having a look, thanks again:),
BlindFaith
TBS 5925
here reception is poor :( SNR=6,7 dB with 120cm and TBS5925
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Same here....nothing.
Plenty here and able to lock the data channel on 10919 H 45000 but not 10731 V 45000 ***!!!
Enjoy your weekend all. :)
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Something not right I had another go at these channels just now with my DB 8000, Yesterday I used my DB 800se...saw nothing and left it at that...now (just now) I saw MBrincat thread and went straight to my DB8000 and viola they there were (Dish 1.2).
The Snr is a bit low 46% though.
BlindFaith
TBS 5925
Something not right
yes indeed.. According to crazyscan the mux is signalled as ACM/MIS (only a one input stream active). If you check the mux with TSReader the mux rate is 28,5Mbps whereas a carrier with 45000MS, 8PSK, 2/3 yields 54Mbps. No problem with TBS5/6925 but how is that possible with a DB8000?
