Newbie Here Station moved from Hotbird to Eutelsat Hotbird
john kimon
I have a 1m dish that picks up hotbird and astra and a smaller dish for Hellas sat. I have a digital receiver.
London, England
A station I watch, RIK Sat, has just moved from Hotbird 13°E to Eutelsat Hotbird 13°E.
I know this sounds a stupid question, but are Hotbird 13°E and Eutelsat Hotbird 13°E entirely separate? Has my Hotbird 13°E LNB now become obsolete for my purposes and to receive RIK Sat am I going to have to invest in and instal a new LNB that will be able to pick up Eutelsat Hotbird stations?
Thanks in advance.
Welcome to the Forum :)
Same, same.
Same position, same LNB.
The renaming of craft has no material effect. All three birds at 13E are operated by Eutelsat.
There are two FTA instances of RIK Sat at 13E:
11585 V 27500 (This is the new one)
12111 V 27500 (This is probably the old one)
john kimon
London, England
Same, same.
That's encouraging. So, what do I need to do to retune the channel?
The new frequency is below, but I've not been able to find the station when I manually enter the details and an automatic scan of the LNB doesn't produce the station either. What am I doing wrong?
Satellite: Eutelsat HOTBIRD at 13º E
Frequency: 11585 MHz
Polarization: Vertical
Symbol Rate: 27500 Ksyb/s
FEC: 3/4
11585V
27500 3/4 is correct - Ive just checked for you & RIKSat is most definitely there.
Well the parameters are the same as I posted above, so in principle there's no reason why it wouldn't work - Give me a few minutes until Masterchef finishes, and I'll have a look myself.
Edit: No need now! ^^^^^^^^^^^^^^^^^^^^^
So, what Make/Model Receiver are you using?
Sometimes it helps if you delete the old version of the Channel as when the box scans, it might ignore what it sees as a duplicate (Based upon the name).
john kimon
London, England
11585V
I'll try again. I must be doing something wrong.
As stated, try deleting the original instance of the Channel before you scan again.
john kimon
London, England
I've tried again, with no joy. My receiver is a Technomate TM-500 Super. It shows up the relevant satellite as Hotbird 6/7A/8.
To tune to new frequency, I go:
Menu>Setup>Satellite Installation and TP Edit>Manual Satellite Search, which brings up a screen asking for:
Satellite: (Hotbird)
Frequency: (11585)
Inv: (which I leave blank)
Polarity: (Vertical)
Fec: (3/4)
Symbol Rate: (27500)
Lock and Sync are checked
Use ONIT, Use BAT, Only Free and Network Search are all unchecked.
This tunes some 17 channels, but none of them include RIK Sat.
Any ideas?
john kimon
London, England
I haven't tried deleting original channel. Just seen those messages. Will try that now.
pontiend
Contibruter
south yorkshire
I have looked at those two transponders.It is banging it down here.
11585V 27500. is coming in at 89%. As posted above RIKsat is there.
It is not on 12111V 27500.
These are some of the channels that I get.
TM5402HD 100 cm Dish
john kimon
London, England
Frequency: (11585)
Fec: (3/4)
Any ideas?
Did deleting the old one before scanning work?
john kimon
London, England
Tried deleting old RIK, then manually and automatically scanning Hotbird, and still no new RIK.
That's bizarre - I really don't know what more to suggest.
Unless one of the 17 services you do get from that TP is actually RIK Sat but is incorrectly identified - are there any unspecific Channel Idents? Try viewing and seeing what lies beneath.
Final thought before bedtime: 11585 is very close to frequencies that can be affected by DECT Phones ........................ If you have one, try turning it off before you scan again. Clutching at straws, really.
john kimon
London, England
Tried seeing what lies beneath, still no RIK. Channels coming up are Italian Free to Air and Rebel TV. There is a cordless phone in the room, will now try scanning with that switched off.
john kimon
London, England
Turning off the phone while scanning didn't do the trick. Still comes up with 1 transponder searched with 17 channels – none of which, unfortunately, are RIK.
