Broadband Speed
2cvbloke
Near Pontop Pike, Co. Durham
(and then some PF100 to the router - but Virgin don't know that!)
Given that VM do self-install kits, it's only logical to throw the rubbish they supply in the bin and use quality stuff instead...:D
Archive-8
All the ip cams have started flashing, my download speed has dropped, from a throughput of 17mbps to 10mbps, all while the modem says its 21mbps.
I will have to wait until after 1pm as that's when it normally drops to 0.33mbps.
@Milamber @Lazarus do you still have the yogurt pots and that string?
2cvbloke
While out in the garden I tried seeing how far down it I could get with my new (to me) Netgear router, turns out it reaches further than my old D-Link router, but that aside I saw my 4G signal was rather strong, so ran a speedtest on that, and, well, I'm happy with the results... :D
The highest I had standing almost next to the mast was 76Mbit download. Almost double the speed of my home connection...
2cvbloke
Makes me wish I still had unlimited data on my phone account, especially when compared to the "fibre" internet I have:
Archive4
Well, to be honest, what do you expect from a connection made from bran flakes!
2cvbloke
But they say bran flakes keeps everything stuck together... :-rofl2
2cvbloke
It does, apparently, sticking the 1 to the 0 can cause serious data errors, I would imagine:D
Well, I guess using 2s to stick 1s and 0s can be problematic... :-rofl2
sonnetpete
wordpress.com
Normandy, France
Staying at my Mum's till Tuesday and just tested her broadband with this result :
She has a problem with Skype being really slow, which I suspect is due to the upload speed being .37mbs. any ideas if I'm correct?
Is that urban, Pete, or rural?
sonnetpete
wordpress.com
Normandy, France
Langley Park is semi rural I suppose, though it's a reasonably sized village. ~She's been having problems for a few weeks now, though we made a test call from SWMBO's I Pad to Mum's netbook......it seemed to be quite swift albeit I was standing in the bedroom and they were in the kitchen.....
Recommended speeds for Skype are here
And I suspect that confirms your suspicion about the Upload Speed.
battenfan
1.2m pf
60N 18E
Netflix has started their own speed test: fast.com
Seems fast enough for an audio only connection but probably a bit choppy if you're doing video as well.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Sometimes shows Zero ms when I use Ookla .... I suspect it's a glitch ....
Anyhow, the more striking news is that Chris is being well served by Cowes.
