Sounds like you're sorted altho 1w should be bit more. Presume u mean db levels .Manikm909
Its very over cast and raining but not very heavy as i write this
readings:
1 west sky news 14.00 snr
30 west TSA RECORD HD 16.50 snr
42 east 24 hd 17.00 snr
53 east kurd channel hd 11.50 snr
https://www.ofcom.org.uk/__data/assets/pdf_file/0016/232108/frequency-allocations-mobile-broadband-below-5ghz.pdf
Yes, a declination issue, though the limits of the dish (and the possibitiy the pole is not level ) will probably be key.Sounds like you're sorted altho 1w should be bit more. Presume u mean db levels .
yes, been there as long as the dish, thing is, im sure i had these satellites with no problems, then we all had signal issues when they installed a new 5G mask, but im not sure on the times when all of this happened, hence why i did wonder about the new style LNBs.Yes, a declination issue, though the limits of the dish (and the possibitiy the pole is not level ) will probably be key.
Is that a conservatory below ?
Which receiver ?yes they are db levels.
Im going to try a different LNB when it arrives, i use to get 7 west most of the time, now i dont, 16 east is a problem on SIC INTERNATIONAL does 5g mobile signals cause problems on satellite, this 7 west is strange, dubai racing, i use to get, in hd, now its all over the place, the signal seems fine of about 8 db 42 signal the top part of the picture seems to be ok, but the bottom is crazy.
I wonder if there is some kind of interference, our tv signals was effected by a new 5G mask (normal tv via ariel) not that long ago, this signal goes from 8 db to nothing then it comes back on again, ive never seen anything like this, ive removed all the dish cables as they where in some trucking which ive heard can interfere like a cross talk, that hasnt helped.
and above all this antenna should be green!Sounds like you're sorted altho 1w should be bit more. Presume u mean db levels .
