16 east and 7 west
Did the satellite guy check your rim for issues ?
sorry no idea what you mean
Going to put the old lnb back on when the weather improves, and have a good play around, only getting 85% signal on sky news 1 west as i write this, but i did say to leave it peaked on 7 west, so going to have a play with the old LNB at a later point
Why did you not get your satellite guy to change the LNB and set it up with his spectrum?
Jason001
channel master 1.2
norfolk
good question, he spent some time with the new LNB and said he didnt think the LNB was the issue, as i had tried the older LNB before, but now im getting some lower signals so might as well play again, but good question and a vaild point.
Jason001
channel master 1.2
norfolk
He just concentrated on the dish problem CH
He tried to get could get more out of the dish, moving it up/down left and right, but no luck, he also tried skewing the lnb and again moving dish up and down, left and right, no more signal could be obtained.
Im gong to put the older LNB back on again, as it has a lot longer neck, so ill try to skew that again and i can move the dish closer or further away from the dish face, but im sure i tried that before.
He says for sure, that dish is line up fine, he tried 16 east, 7 west, 1 west, 30 west, 53 east, and couldn't get no more out of it, this is another reason why i want to go back to the older LNB, maybe the focal point is out, or the LNB needs to be closer to the dish, with the new LNB you cant move it in and out of the dish like the old one, but as i said, im pretty sure i did that before.
The other thing is have channel master dishes, over time gotten better, mine is really old 25 years at least, but he couldnt see any issues with the one i have, but did wonder if the newer ones have improved, like the older cars against the newer ones, in miles per gallon etc, they keep improving over time, other than that, im at a lost, he confirmed ber on 16 east SIC INTERNATIONAL channel was on his meter as well, which was direct into the LNB
My mistake for asking for a rear image as well.
It certainly is an interesting problem jason, my 1.2CM in use is well over 20yrs of age and the only thing iv'e done to it is to re-position the actual lnb holder and lnb pointing angle from original factory position using data supplied on the forum in a dedicated Channel Master dish topic. Focal point setting done using readings from an analyser and skew used to be motorised but not any more.
For a temp set-up , I'd be tempted to use / try a longer neck single lnbf with a fresh , good, short run of coax into a cheap signal meter and evaluate. The altering of the lnb holder position is more involved.
Yes , very incriminating
Jason001
channel master 1.2
norfolk
Hi John thanks for your comments
Channel Master dish topic is it this one you are talking about
can you post your readings on 7 west please on ad sport 1 hd, if you can get 7 west, and also post the reading on sky new on 1 west please.
thanks
Manikm909
Small'ish Dish Man
Kent, UK
it wont be the dish age - however it could be warped, can CM's warp?
everything so far points to a smaller than specified dish, like a 1m CM
i dont know what would cause that - r u sure theres no damage to the dish face, or the rim?
Jason001
channel master 1.2
norfolk
Hi, for sure its a 1.2 metre dish, he measured it, it is 1.2 metres in the width 1.3 metres in length, he showed me with his tape measure.
I cant see any damage on the dish, and he didnt either, but i am being to think of getting a new dish face, this is really getting to me now, when it started it didnt bother me much, but over the weeks its getting on my nerves big time
If i could get a 1.2 channel master 2nd hand, that is something i might well think about.
Manikm909
Small'ish Dish Man
Kent, UK
i have a spare, but far from you
r u sure theres no trees or anything blocking signal...
Manikm909
Small'ish Dish Man
Kent, UK
peterborough,...
Jason001
channel master 1.2
norfolk
Hi there is nothing in the way, ive posted these in case anyone can see any damage to the dish itself, i cant from the windows ive taken the pictures from.
Unless there obvious is damage I don't think it will make the slightest difference getting another dish face..SMC dishes such as Channel Master rarely mishape.
I would start to look elsewhere, the coax from the LNB to the VBox might worth being replaced for instance..or at least try a temporary length to compare.
Satfaca
Melmac (46N, 14.5E)
Melmac
As always in such cases (when banging head to the wall by not finding any reason...) ... check the cable going from the dish to the receiver in its entirety!
Manikm909
Small'ish Dish Man
Kent, UK
the satman went direct from LNB to his spectrum ....
Jason001
channel master 1.2
norfolk
the satman went direct from LNB to his spectrum .... yes confirmed
front view of dish, anyone see any damage, there is a slight mark at the top, but thats been there for ages, and I dont think it is damage I guess dirt, to be honest.
thanks
Can you give me the frequency of 'ad sport 1 hd' on 7 West please
** The CM pointing mod was covered by either members RimaNTSS, or A33, can't remember what the topic was described as at the moment
