16 east and 7 west
Jason001
channel master 1.2
norfolk
here is where it states the size of dish - so should say 1.2m
Hi yes, i can see clearly it states 1.2 metre made in the usa, but on my camera phone you cant see it clearly, with my eyes wearing my glasses i certainly can
Manikm909
Small'ish Dish Man
Kent, UK
Hi there Manikm ....
Pretty certain its just a North / South footprint issue ... always had difficulties with 7 West up here
Alignment etc seems good ... screen shot of sky news at 1.0 west below ....
same as me on 1w then @nelson_b - r u sure your arc is bang on the money ?
arent you up by @John - he can get AD SPORT 1
@Jason001 im currently getting 6.5db on MBC3 - watchable, no glitch, and 9.8-10.2db on AD SPORT 1 - blue sky \ patchy clouds, but bright out.
Jason001
channel master 1.2
norfolk
@Jason001 im currently getting 6.5db on MBC - watchable, no glitch, and 9.8-10.2db on AD SPORT 1 - blue sky \ patchy clouds, but bright out.
i guess that is the weaker mbc not the stronger one at freg 11277 v
Manikm909
Small'ish Dish Man
Kent, UK
I concur Nelson. It was below lock on my Precision 1.3 also. John is way more to East than me. We had a similar issue with TV1000 many years back. Signal for me would fade to nothing early evenings ok 24/7 for John.
Manikm909
Small'ish Dish Man
Kent, UK
im really surprised theres so much difference, we're all on the same tiny little island.
nelson_b
Contributor
I,m a lot further north than @john ..... i,m just 40 mins drive from the bottom of the lake district.
I,m a lot further north than @John ..... I,m just 40 mins drive from the bottom of the lake district.
Arc is very close to spot on ... I also have elevation control, for ultra fine tuning on the 1.2 - so can always get the best out of it. :-)
Jason001
channel master 1.2
norfolk
Hello all, a further update.
So today i went to the dish and i could see the 1.2 metre dish at the back, so 1000% it is that size of dish.
On 1 west sky news, i managed to get a signal of 95% 15.00 db to 15.50, that is the highest reading i got, so i left the LNB there im now using the older long neck black ultra
However now i cant get 7 west at all on ad sport 1 and 2 hd i do see a signal going from 0 to 45% but no picture, but i do hear a picture now and again.
If i skew the LNB so i get a picture on AD sports then i lost the good reading on sky news, it goes to about 83% signal snr, but even then i still cant get mbc 4 5 etc on the weaker freg.
I think im not going to cure this, ill have to skew the LNB so i get some of 7 west, and lower the signal on 1 west.
I did push the dish up and down and again saw no improvement on the signal.
thanks
Jason001
channel master 1.2
norfolk
7 west
signal all over the place, from 47% to zero
Manikm909
Small'ish Dish Man
Kent, UK
U might need to move the whole assembly slightly on the pole and peak at 1w and then see how 7w looks
I had to do that . When u centre for sky news. Was the dish bang on straight or had u moved the motor a few clicks to 1w
Jason001
channel master 1.2
norfolk
ive just turned the LNB a weak 7 west now comes in, but its gone very dark here and now its gone, the readings on 30 west are 99% 53 east is 70% on kurd sat channel. so i think i might have to pass now, if the dish isnt tracking the arc correctly then it will have to stay that way i feel, i think not having a polarizer is not helping, but i know i use to get 7 west better than this a year or so ago, but unless someone has any other ideas, that are easy to try, i think im beaten to be honest.
Jason001
channel master 1.2
norfolk
im finding that some are stronger than others on 1 west, however if i move the dish a tiny bit on the postioner they increase, but then i lose a small fraction on the other channels, but i see some of these satellites are 0.6 07 and 0.8 so i think that is why.
Ill move the dish to 1 west now and see if it is straight or not
Jason001
channel master 1.2
norfolk
This is the dish at 1 west, its not bang on straight very slightly do the left, but i guess that dont mean it is not tracking the arc correctly, i couldnt get any more out of the dish pushing up down left or right today, and when the satellite guy came, he couldnt either.
Manikm909
Small'ish Dish Man
Kent, UK
the motor and dish needs to be exactly central on the pole when you're tweaking 1w on sky news, if its out by any degrees, you'll find 7w will be out - you're very close dont get me wrong...but this is what you need to pay attention to, unless you're happy giving up.
theres no point adjusting skew after on any other sat other than 1w - if you want a universally strong signal across the arc. (in my experience)
Jason001
channel master 1.2
norfolk
Hi, how can i tell if it is nor not please, would it help if i post photos from the side as well.
Also another question if the dish is not central would you still get more signal by moving the dish up and down, because ive found you dont, it seems like it is a max.
thanks again
Manikm909
Small'ish Dish Man
Kent, UK
thanks again
depends on what sat - if it needs nudging over on the pole to get more signal on 7w, then yes, you will need to slacken off the bolts and nudge it, however, this should be done on 1w....rinse and repeat.
Jason001
channel master 1.2
norfolk
HI which bolts please.
So are you thinking the dish is not quite on the arc?
Manikm909
Small'ish Dish Man
Kent, UK
The motor clamp bolts. U can't be on the arc if 7w is missing
Manikm909
Small'ish Dish Man
Kent, UK
Why do u care so much about 7w ...I never go there
