16 east and 7 west
Satfaca
Melmac (46N, 14.5E)
Melmac
I seemed to me strange in the first place ... this cannot be as it coincides with Nilesat 201's 11.727 H.
In the morning hours 201 comes in very weak and 11.742 H could have been "a ghost reflection" from Eutelsat 7WA's 10.892 H off Nilesat 301..
Will try to observe tomorrow again.
Manikm909
Small'ish Dish Man
Kent, UK
Can you give me the frequency of 'ad sport 1 hd' on 7 West please
** The CM pointing mod was covered by either members RimaNTSS, or A33, can't remember what the topic was described as at the moment
11411 H 30000 - 10.2db for me
Manikm909
Small'ish Dish Man
Kent, UK
Re: 7.2West,
Anybody to confirm
New to me on 1.2CM, Central UK.
11.742H, 27500, 7/8, fta
Test 1 , Test 2.
nothing for me - at present time
Hi John thanks for your comments
Channel Master dish topic is it this one you are talking about
can you post your readings on 7 west please on ad sport 1 hd, if you can get 7 west, and also post the reading on sky new on 1 west please.
thanks
Did the satellite guy check your rim for issues ?
sorry no idea what you mean
Going to put the old lnb back on when the weather improves, and have a good play around, only getting 85% signal on sky news 1 west as i write this, but i did say to leave it peaked on 7 west, so going to have a play with the old LNB at a later point
I did suggest taking pictures fom the side, in case you have a warp that others can confirm from the imagery.
Jason001
channel master 1.2
norfolk
Freg is 11411 h 3/4 for ad sport 1
8.25 to 8.50 db here 50% snr with no ber at the moment
Jason001
channel master 1.2
norfolk
Manikm909
here is where it states the size of dish - so should say 1.2m
ill check, ill see if i can go up and check, but im sure its a 1.2 metre, as it replaced a 1 metre dish that i still have, and it was alot bigger than the older one i had
Manikm909
Small'ish Dish Man
Kent, UK
your 1.5 -2.0 db down if its a 1.2m
nelson_b
Contributor
Just had a look here - at 11411 H .... with 1.2 cm .... but i,m way out of range up here in the " North West" - no lock at 7.2 d.b. ... here so a little under 1.0 db short - according to Lyngsat .
Manikm909
Small'ish Dish Man
Kent, UK
hi @nelson_b good to hear from you! i think your dish might need a tweak mate.
Manikm909
A wasted exercise if your installer has already confirmed the dimensions.
It is the first time you have mentioned the dish face was replaced, how long ago ? and where would the old reflector be now in case you have to reinstall ?
thanks
Manikm909
Small'ish Dish Man
Kent, UK
Here's the frequency / Channel check you requested for 0.8W for Sky News.
Meter marker on 12.418 V ~ No carrier present at the time of grab and now 9.25am.
15.5db here (through VBOX)
Satfaca
Melmac (46N, 14.5E)
Melmac
Re: 7.2West,
Anybody to confirm
Test 1 , Test 2.
No signs of this anymore, who knows what was it...
Brain fart occurrence took place on that grab - 18v somehow got up the coax and switched the lnbf to H... doh
Here's the propper grab ... 1.2m CM, North Notts, cheap Universal lnbf.
nelson_b
Contributor
Hi there Manikm ....
Pretty certain its just a North / South footprint issue ... always had difficulties with 7 West up here
Alignment etc seems good ... screen shot of sky news at 1.0 west below ....
Jason001
channel master 1.2
norfolk
hi Channel Hopper
This was many years ago, 20 i would say, for a few years i has a 1 metre dish, then it was upgraded with a 1.2 metre, i can see out of the window it says made in the usa and it states its a 1.2 metre, getting a picture of it is hard, but ill try.
Now last night was watched mbc 3 on 7 west, for the first time, why i have no idea, it was perfect, this morning its freezing and blocking again, which i can understand as the signal at night will travel better, and the lnb is colder.
