blademedia
- Jul 29, 2016
- Sky
- UK
Hello nelson what satellites are viewable with the dish at this location have you had a look at nilesat 201
Must be an north/south thing - it's coming in OK here on 1.8m.
Absolutely sod-all on 25.5e though. Not a blip. We really must be in a null here.
Signal levels pick up later in the day 36E will be of interest for me do you have LNB for testing here would appreciate any test, I get mena beam ok with 1.2 and a hint of nwa beam weather/ timing is /importantHi --
I can see 46 east o.k .... a few degrees further will be possible if i skew the towing caravan back a bit ....
west ? 30 - 40 not sure i need to fix the (short ) jack that i,m using to the other side to get that far ...
i can see 7 west ok without moving it .... can,t see anything from Nilesat 201 though ...
i can see 11595 V 22000 from E7WA , its listed as being on the NWA beam ... i,m sure it is looking at the signal db.... its a first for me i think..... the ME-NA beam is strong.
View attachment 98473 View attachment 98474 View attachment 98475
Interesting do you get any signal on the massive dish from 201 would like to see pictures of the big oneMust be an north/south thing - it's coming in OK here on 1.8m.
Hi nelson_b,
You got a very good buy from eBay with that 2.4m CM dish and kit. The actuators are probably worth what you paid for the entire kit excluding your travel costs. I think you got it from the seller who also had the 3m Precision dish and the 4.5m dish for sale around the same time on eBay.
I am looking forward to your installation and it will be interesting to see what the 2.4m CM can achieve in terms of C, Ku and Ka bands and how they compare with the dishes of the small men. If I were to guess, I would say the Ka band might not be spectacularly greater than a high quality single piece slightly smaller dish but the C and Ku should really illustrate the power of a 2.4m big mans dish.
Hope the installation proceeds well and best of luck with it.
Rgds
Nope, pretty much nothing. I get what can only be described as blips on one or two frequencies but it could be as much as just ground/sky noise.Interesting do you get any signal on the massive dish from 201 would like to see pictures of the big one
Hi -36E will be of interest for me do you have LNB for testing here would appreciate any test,
@nelson_b - would be interesting to see 36E results on circular Russian transponders.
Hi -
Do you mean the circular transponders ? i, v locked a couple of them briefly in the past on 1.8 using a C120 l.n.b. and channel master feedhorn with original dielectric plate ....
I'd be interested as well. I just looked using the 1.5m PF. H are marginally stronger than V but it could be skew error. Most tps are ~1dB SNR although 25E is very close to some trees which give ~4dB ground noise at 28E. My calculations suggest a 4.7m dish for 11dB SNR. If the 3.8 wasn't in the shed in bits.......Very rarely post on big boy threads, but I would be very interested to know if you can pull this in on 25.5e Es'Hailsat
11623
Vertical
27500
2/3
DVB-S2
8PSK
11623
Vertical
27500
2/3
DVB-S2
8PSK
Hi -
@Captain Jack & @blademedia
Heavy showers here prevent me changing the l.n.b. + feed for 36E circular t.p.,s ..... so far tonight
I found the old postings - on here to refresh my memory about which transponders were strongest when a number of us were trying to lock these in the past ....
36B at 36.0°E (long thread)
and another ...
36E (Eutelsat 36B)
the situation regarding 12092 that "archived-1" first spotted - still exists (im getting occasional lock here a with a normal l..n.b. set to H polarity) ... the only difference is that unless my memory is wrong ? it needs much higher db level to lock than it used to ... no chance with 1.8 anymore here .... Maybe you can C.J.?
Good going with normal lnb and conditions, should gain approx 3db with correct one thanks for taking time to look and links will have a read
