2.4 Channel Master Offset
blademedia
Sky
The odd thing is i could never lock this one with the "circular" l.n.b. only the normal one? ... it was another two transponders that i managed to lock on the 1.8 with circular .. :-lol
Did you change lnb setting at the time ?
nelson_b
Contributor
My "circular" l.n.b was just a universal C120 (inverto Black pro i think) with a plate in the channel master feed ...
blademedia
Sky
nelson_b
Contributor
bought controller from this guy and actuators
In my receiver I have lnb setting for circular this link might help with rest
How to set up circular polarisation
You acquired some nice kit then ... :)
Thanks for the link .....
No separate settings in the receivers i currently use, for circular. .... my old Vantage had i recall .
i just set V for Right circular and H for Left. in the F15 .
still thick cloud here tonight .... no good for weak k/u signals ... another time :)
blademedia
Sky
yes good kit, next time you try for 36e with correct lnb set lnb setting in receiver to 10750 and see how you go with that :)
Retired human
I have a circular Ku LNB if you want to try that, Nelson?
nelson_b
Contributor
Hi- C.J
Is it an Iverto ? -- would you like to sell it.
or are you wishing to hang on to it, and send it me just for testing ?
Retired human
I have little use for it so you can have it. It's an Inverto yes - 40mm one.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
That are settings for 36*E Circular I have in my receiver. ScreenHunter_72 Sep. 29 22.56.jpg
But, if somebody in need of Circular LNB, I can look in local shop and mail it, I do not think they are too expensive.... maybe 5EUR, plus another 5 EUR for mail.
blademedia
Sky
lnb voltage for 36e circular R =V /14 volts L=H /18 volts
nelson_b
Contributor
Thank you - C.J. - i owe you one :)
i will refund your postage costs etc .... Do you still have my adress details - or shall i message you ?
regards ...
Retired human
Message me your address please.
Trust
Nijmegen Netherlands
That are settings for 36*E Circular I have in my receiver. View attachment 98502
Hi Rimants , are they full Ku band ? I like to have one .
Retired human
Those circulars are 11700 to 12750 only, I believe.
RimaNTSS
N-E from Riga
Sorry, @Trust1 , I did not check that before, but seems that CJ is right..... those LNBs are 11,7 – 12,75 . Do you still interested in one?
nelson_b
Contributor
As the weather cleared this afternoon and i,m probably going to be out and about most of this weekend i put the universal/circular setup on this dish ...
No more of the Russian transponders were gained ... just got the three (now with a decent margin) that had very occasional/ marginal lock on the 1.8 1n the past .. the only difference being that 12092 now locks on the circular setup and is now the strongest -- where previously it was the weakest on circular and would only lock with a linear l.n.b. on wrong polarity ...
i tried 3 different C120 universals on the c.m. feed + plate
Inverto white tech
Inverto black pro
and Invacom quad
to be honest they are about equal ... the black pro had 0.1 db over the other two .
Such a pity that everything is encrypted here on these three transponders :(:(
Retired human
I am still amazed that you get this so far out of official footprint. This is my Holy Grail to get in the UK but getting absolutely sod all.
Ironic that the centre of footprint for the Russian beam is hovering above my home town....
Nelson what's your sub Saharan beam like? I bet you'd get a lot more of the Russian beam if frequency reuse wasn't there. I get 12245H and 12054H for DSTV (nice to see old names like Supersport scanning in).
Retired human
Multichoice Supersport. Used to be part of Scandinavian package along with things like FilmNet.
