nelson_b
Contributor
- Jul 27, 2008
- Age
- 73
- Strong 4375 driving a 2.4 m Channel Master dual focus offset + Invcom Quad C120 K/U l.n.b. + BSC 421 and Zinwell C band l.n.b.,s - DR HD F15 - TM5302 - Octagon SX88+Optima - GT Media V7 - HD receivers. + other dishes currently in use - Antique 3.0 m Prodelin P.F. - Channel Master 1.8 m offset - Channel Master. 1.2 m.
- North West Yorkshire - near Lancashire & Cumbria borders.
Additional info --
of the 2 transponders that have signal on both polarities there is a about 0.2 db difference of strength between the polarity on both frequencies ...
now it gets a bit weird
if i scan in using the stronger polarity reading on 12149 i get the 24 channels that i should get from that t.p. .. if i scan the weaker polarity on 12149 i get the 7 channels that should scan in from 12130
the same thing happens in reverse if i scan 12130 the stronger polarity brings in the 7 channels that should appear.... and the weaker polarity pulls in the 24 channels from 12149
12092 is normal and only has signal on one polarity and pulls in the 26 channels that it should do
make of this what you will ... i,v never had this happen in circular C band
