That must be a pig to align when it does go out
It’s sturdy enough and survived without latest metal strip through 3 major storms.
When high wind pressure is on I have to change the longitude a bit, say from 3.1 to 3.0 / 3.2
This only affects the weak satellites.
If i had fitted t&k brackets, I would still have to bring the dish outwards and use the same small balcony bracket.
This was the only way to fit the dish on the side wall. Front wall installation is not allowed in the area.
I had to make a wooden model of the both brackets and a cardboard model dish to find the measurements.
If there is a will, there is a way.
