53E (Express AM6)
stephan94
Bavaria
Today I was able to receive 10974 H 4850 for the first time
In the center of Poland it could be received with almost 20 dB.
for me still with 6 dB
At 12:20 (CET) it was finished, no more signal
semёn
motor-37,6w-95,0e , 0,9m-4,8e-9е-F-13е , 1.2m-19,2e-23,5e-28,2e-F-36e , 1,2m-80е-F-90e , 1,2m-30w , 1,2m-53е , 1,06m-75е , 1,6m-90е-С-F
Denys H.265 PRO. Openbox SH6 HD
Belarus - East of Minsk
I checked the satellite in the evening using a stationary 1.2m antenna,signal from the Denys H 265 PRO receiver. From the Openbox SX6 HD receiver, the signal is 7-10% higherThe weather is cloudy. In sunny weather the signal is 2-5% higher. The signal on 10974 H 4850 3/4 dropped by half. This happens to them often. They will fix the signal soon. In order to receive all frequencies in the T2-M1 format, I adjusted the antenna to approximately 52.5e. At the same time, I receive channels from the satellites TürkmenÄlem - 52° E - Belintersat 1 (ChinaSat 15) - 51.5° E.
Fixed-1
T2-MI
-10713 V 14181 - 77% quality
-10717 H 22895 - 52
-10730 V 14182 - 82
-10747 H 22895 - 56
-10749 V 16407 - 69
-10839 V 15284 - 56
-10875 V 15284 - 81
-10907 V 28724 - 64
-10855 V 2828 - 69
-10862 V 1808 - 87
-10974 H 4850 - 44 - in sunny weather - 87%
Fixed-2
-11011 V 2200 - 77%
-12508 V 1100 - 59
-12632 V 3000 - 84
-11457 H 3462 - 77
-12659 V 4080 - 74
-12594 V 27500 - 90
-12679 V 1666 - 59
-12512 V 1815 - 59
52e
-12303 V 27500 - 100%
-12264 V 27500 - 100
-12399 H 18300 - 100
51,5e
-11290 H 45000 - 84%
-11350 H 45000 - 87%
stephan94
Bavaria
And today only 4.2 dB instead of 6 dB yesterday, so unfortunately not visible.2024-11-12 09-05-06.mp4_20241112_090629.569.jpg
In my area, the signal at 53.0E looks like this on these muxes.
On 11179 V,5300,3/4, we have an IP-over-Sat stream with a media content from the RSCC provider.
stephan94
Bavaria
and today it got even worse, only 1dB and not stable (bad weather with drizzle)
semёn
Everything is normal with a signal on 10974 H 4850 3/4 Samara and its region. My signal is now 84% quality. Antenna 1.2m. Because of the rain, your signal may have been reduced. Question, is there a protective visor on the =head= LNB
stephan94
Bavaria
What wasn't normal was that one day the frequency was so strong for a few hours that even though I was completely outside the reception area I was able to receive beam KU fixed 1.53 east.jpg
2night
vantage hd 8000s
120 cm dish
windows 7
friesland (nl)
And at the moment there is no signal Telekanal 78 -/Piter/-11154 H 3500 3/4 - 0%
Dear colleagues, good afternoon!
Broadcasting via the Express AM7 satellite was terminated due to unrecoverable interference on the operating frequency.
From 03.12.2024, the broadcasting of the TV channel "78" is carried out through the new satellite "Express AM6" 53 degrees East.
Parameters for setting receivers are :
10992 h 3500
adonis1
10992 h 3500
at 6.7 db with 1.50m
dreamsat
germany
here too
dreamsat
germany
Telekanal 78 can no longer be received or is currently switched off.
