57E (NSS 12)
Tururu
Assembled with recycled parts
Recycled as the owner.
Place another antenna as I have in the highest "moto" 100cm and partially jump the guardrail, targeted in 10 minutes.
Funny thing, 500 meters I have some trees that I probably already removed signal, within a few years long story, but for a few days, no problem.
Colocada otra antena como la que tengo en la "moto" 100cm mas alta y saltar parcialmente el quitamiedos, en 10 minutos apuntada.
Lo gracioso, a 500 metros tengo unos arboles que seguramente ya me quiten señal, dentro de unos años ni te cuento, pero para unos dias, no problemo.
DUHOK en 11189 V 1775 3/4 DVB-S2.- señal/SNR 53%, Calidad/AGC 99% BER 0, 8.5dB
Some party photos/Unos fotos del partido del RM & PSG.
PD:Buena pesca/Good fishing.
PS: Now I just need to like football/Ya solo falta que me guste el futbol.:-rofl2
Europesat
strong
Yemen
Thanks all
Here in Sanaa we receive very easy with small antenna like 60 cm
pontiend
Contibruter
south yorkshire
On DVBDream I have just noticed that DUHOK seems to have gone encrypted.If so no good looking there for the Man U match.
Jamie A
I noticed that yesterday too. Key already available if you know where to look :)
adonis1
Citizen TV (Kenya) started broadcasts
11140 H 3100 (East Africa Beam)
Is that a Citizen TV feed, adonis1?
Because I see no peak whatsoever there.
Another signal since this afternoon, not sure if it's a feed, maybe Kurdish previously on another freq.?
Black screen now but 2 audio tracks.
11043 V 1210 3/4 DVB-S2 QPSK
Edit: this will be Qellat, previously on 11184 V, other parameters are the same.
blademedia
Sky
11043 has been there for a few weeks now, ever time I check green dots over black screen.
adonis1
No, I think that's the regular channels program.
The channel signal it's very weak (4.8 db)
adonis1
Feed (Kenya beam)
11182H 1345 at 10,4 db (quite strong signal)
Kypros_Pambou
TBS:6985,6925,5925usb
5 Pace&Arris IPTV Gateways
Greek Cyprus
There is no signal from Cyprus (11605 Hor)
Kypros_Pambou
Greek Cyprus
Reception with 3.4m
Kypros_Pambou said:
Reception with 3.4m
I am surprised that you can not lock 11604 H(Data-generic stream) with your antenna of 3.4m the more so that FlySat give on spot EastAfrica,much closer to your area than in the eastern-central-northern part of Europe.It is true that the signal is not constant and fluctuates between 1dB and 5 dB,depending on weather conditions.
Something isn't right,or the signal isn't on the spot East Africa, or comes from Central Asia?! But whichever spot is this transponder,though you are far better placed toward us from those two spots,and if we also take into account your huge antenna,everything should favor the reception of 11604 H!!!You must check in your system of reception and then try again.Again I say,something isn't right in this system.I hope I am wrong.
Here are the strongest signal at 11604 H I get in my area with 150 cm dish,in north-western Romania.
Kypros_Pambou
Greek Cyprus
Also for me is very strange that i can't lock the specific frequency. Is not the first time that i'm very closed to a beam and i can't locked it :(. Both motorised dishes are very well installed with accurate inclinometer,prof.laser pointers and my Rover HD Tab 9.
The ME Beam comes with my small dish (2.1m) from 14.2db - 17.6dB
It's really weird.Who knows,maybe you can have interference from a mobile cell or from other sources?Can be seen on any spectr.Look how shows such interference on CS.
Edit:An example between a signal interfered with and one normally,without interference on the same frequency.Test done with two antennas installed in two different places.
Kypros_Pambou
Greek Cyprus
During morning hours i have increase of 1dB signal. About the intrerference i have to check if exists this possibility. This morning i locked with 2.1m and freq.(11671 Ver - Data = 10.8dB ) from CA but nothing from EA :(
