60E Intelsat 33e
11077-V-8333 now 9,0 db sometimes blocks in image
Yes satkijker, 9.3 dB here and no image at all. 11077 V was fine during the day with 12 dB or so.
But you're just about 23 km away from me, you should have a better signal (1.8 m vs. 1.2 m). VERY strange!
satkijker
See Signature.
Mill Netherlands
I think, a larger dish has an advantage if the signal is weak, a strong signal is minimal advantage.
MCelliotG
Thessaloniki, Greece
I can confirm that the signal is now about 4db weaker than yesterday!
popovp
My system:Receiver-Ferguson Ariva 102E HD, Sky Sat 9900FTA+emu;Ferguson FX-6600CR/OCTAGON SF318 soft;LNB-Sky Sat, universal, 0,2dB;1.17x1.06m offset dish ;Diseqc 1,2 +USALS Moteck2100A motor; 1,2m parabola+0,3dB Inverto @ H-H Strong SRT DM 2100
Varna, Bulgaria
Yes, and here weaker now- 5-7% SQ.
What interests me, is the eurasian beam, though ! :rolleyes:
The good news, Eurasian beam is in use now, as found by @mar-val !
11465 H 21875 2/3 8PSK. Almost 13 dB here.
The bad news, it is a Generic Stream. It has video and audio, but not watchable.
Edit: changed to 9/10 16APSK, only locking on TBS 6925 now.
shawl_who
SES7, Yahsat 1A, Yamal 54.9e, express am33 @103e, eutelsat 36b
New Delhi, India
Waiting for gud european channels to start on it, that way Ill put another lnb to the side of 55e lnb, currently fetching yamal 402 @55e !!:rolleyes:
CERIN
16,0 Е - 140,0 Е
Супрал 0,9м. , TBS-6925 (PCI-E DVB-S2 Tuner Card)
Russia
11465 H 21875, 9/10, DVB S 2/16APSK. :rolleyes:
blademedia
Sky
I think there tweaking beams in to position 11077 V 8332 is coming in fine 7.PNG 8.PNG 3.PNG 4.PNG 5.PNG 6.PNG 2.PNG bg on air.PNG now
Inevitably, I had to play some more with the GIMS software that I found yesterday. :)
Here are the beams covering Europe (Spot # 25, 26, 27, 28, 29, 33, 34, 40 and Wide (Eurasian) beam.
No guarantees of accuracy! Funny things happen in the NW corner of the spots.
But until something better pops up, I like the many contour lines, instead of just one.
The contours may be dotted or solid lines (arbitrarily), but always representing -2, -4, -6, -8, -10, -15 and -20 dB.
IS-33e_Spot-25.png IS-33e_Spot-26.png IS-33e_Spot-27.png IS-33e_Spot-28.png IS-33e_Spot-29.png IS-33e_Spot-33.png IS-33e_Spot-34.png IS-33e_Spot-40.png IS-33e_Wide Eurasian.png
MCelliotG
Is there a change in the spot of the Bulgarian channels? The signal is now stronger than ever! Just look at this!
Also 11622 is back on 604, but weaker than before.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Could receive the 11077 V now .Tried it a couple of days ago but no luck.
Signal is strong 12.80db. Ignore the 57E. I am just using this position to receive the 60e.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Used 1.5 Dish first time, then had a go with 1.2 still receivable with 9db but nothing with 1 mtr Dish.
blademedia
Sky
BNT channels showing a live football game
ludogorets vs Copenhagen
Dreambox DM800PVR
Gibertini OP150
Superjack 1224AZEL
Serbia, Belgrade
@hvdh
I was not able to find your displayed footprint on this link
Notify going to PDF Form
where you have found your shows GXT beams... (29,28,30...)
Thank you :)
Hello Dušan,
Have a look at the Attachment EngineeringStatement, page 14, where the table shows that the Ku-band User Beam Downlinks use the GXT file KUHD (for horizontal) and KUVD (for vertical).
These are the files "Attachment Schedule S GXT 20" (for KUHD) and 21 (for KUVD). This can be checked in notepad (see beam_id). KUHD and KUVD spot shapes are identical, by the way.
If you save such a file with the extension .gxt, it can be imported in GIMS. (I saw in your Telkom 3S screenshot, you have GIMS installed already!)
You will first see the spot centered at 60°E, 0°N, that is without the offset required to have another spot beam.
Then under menu Capture, Squint Beam, play with the Azimuth and Elevation offsets values, until you get the correct boresight Longitude/Latitude values, as listed in page 12 & 13 of EngineeringStatement.
This is very time consuming! I spent a few hours to get the 8 spots that I showed in my previous reply.
It should be possible to enter Longitude/Latitude directly, instead of Azimuth/Elevation offsets as seen from satellite, but I didn't find that!
Hope this anwers your question.
Dreambox DM800PVR
Gibertini OP150
Superjack 1224AZEL
Serbia, Belgrade
I thought you found the files differently from me.
I use Gims too many years earlier.. ;)
(.mdb folder And .gxt file)
I've found/collected/calculate/sending information to Capitan_Uncino site..
This site keeps getting better and better
Fully agree with that! Thanks for your efforts!
