Anybody Got Tbs Card To View Pls Channels On 13E?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Any chance you could rar up version 1.0.1.54
and post it up Llew ..
can't find it at sourceforge
rgds
VS
Thanks Llew ..
Just tried all 4 on 5W with the TD110 ..
Non of them lock
So once again ..I'm confused as to why..
Maybe its the version of TBS card ..
wasn't yours an earlier version..?
rgds
VS
Streamreader shows the version I have -
19:24:19 Device_ID: 0
19:24:19 Use Device 0
19:24:19 Tuner filter: TBS 6925 DVBS/S2 Tuner
19:24:19 Capture filter: TBS 6925 BDA Digital Capture DVBS
19:24:20 Tuner IC: STB6100
19:24:20 Frontend/demod IC: STV090X (cut 3.0)
19:24:20 Current stream mode: TS=1, GS=0
19:24:20 TBS STB6100/STV090X direct control used !
19:24:20 BBGain = 8 dB
19:24:20 Turbosight (SAA7160 based) BDA extension used !
19:24:20 + Turbosight BlindScan support with STV090X
19:24:20 + Turbosight IR control support
19:24:20 + Turbosight I2C access support
19:24:20 + Turbosight fast LNB control support
19:41:22 StopDVB()
19:41:22 LNB power-off ok !
19:41:22 DLL_PROCESS_DETACH hModule = 6D280000
Wasn't there a different frontend/demod IC on an earlier version? I have STV090X (cut 3.0).
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Thanks guys..
ran up the 1.0.1.54 version ..
Still nothing ..
I guess my TBS card is either faulty or has a different front end / chipset..
Not sure how to check this ..
but I _am_ very disappointed ..thats for sure.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
..Which application did you use to interrogate your card Llew ?
Not sure I have it installed ...or at least ..I can't find it
rgds
VS
Well it's the StreamreaderExEx-BDA that came with 1.0.1.54. The accompanying streamreader text file shows the tuner version, as I posted above.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Thanks Llew ...though I'm no wiser ..as the log file made on mine is much the same but for the disqec commands.
If you spot anything relevant ..let me know.
rgds
VS
22:48:47 Device_ID: 0
22:48:47 Use Device 0
22:48:47 Tuner filter: TBS 6925 DVBS/S2 Tuner
22:48:47 Capture filter: TBS 6925 BDA Digital Capture DVBS
22:48:48 Tuner IC: STB6100
22:48:48 Frontend/demod IC: STV090X (cut 3.0)
22:48:48 TBS 6925 V2 direct control used !
22:48:48 BBGain = 8 dB
22:48:48 Turbosight (SAA7160 based) BDA extension used !
22:48:48 + Turbosight LNB voltage control support
22:48:48 + Turbosight 22Khz tone control support
22:49:06 SendDiseqCmd(0x0012D4D4, 4)
22:49:09 StopDVB()
22:49:09 DLL_PROCESS_DETACH hModule = 00470000
22:50:16 StreamReaderEx BDA Ver:1.0.6.643-commited (Jul 27 2011, 20:00:03)
22:50:16 Log level = 1
22:50:16 DLL_PROCESS_ATTACH hModule = 00470000
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
..Hmm why mine says '22:48:48 TBS 6925 V2 direct control used !'
V2 ...more than one version ???
I wonder.....
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Done some digging and there are version differences between V1 and V2 ...odd that my log file reports TBS6925 V2 and Llews just TBS6925 ....which could be interpreted as V1 ...but for the fact that both logs state (cut 3.0)..which according to my digging makes them both Version 2..
This is confusing to say the least ..and I may never understand why I cannot lock and dismantle the data streams.
If anyone has any suggestions to add ...I'd be VERY intested..
Pity Crazycat isn't a forum member.
rgds
VS
rgds
VS
Could try posting a query over at Rick's. Crazycat posts there.
_http://rickcaylor.websitetoolbox.com/
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Tried everything I can think of now ...including a clean build of windows ..just to make sure there are no conflicting apps lurking.
One thing that ocurred is that I am using XPpro..
Can anyone confirm they have their TBScard working with CrazyscanPLS on XP (13 East 11432V) ACM ..
Many images look to be using that WIN7 ..thing...
If all else fails ...I may well remove the TBS and send it to Llew to test in his PC..
Assuming he doesn't mind the inconvenience.
Logical process of elimination is all that's left to me.
rgds
VS
What a hassle to remove and ship the card! Try to contact crazycat, he dropped by today at dxtv.de.
If you're not registered there, I could send a PM pointing him to this thread?
With Crazyscan running, in the logfile (Streamreader text), what do you have after PLSSe 0x08? (that's where you select root 8). I don't suppose you have MISSel at all?
20:08:36 StartDVBEx(0)
20:08:36 Device_ID: 0
20:08:36 Use Device 0
20:08:36 Tuner filter: TBS 6925 DVBS/S2 Tuner
20:08:36 Capture filter: TBS 6925 BDA Digital Capture DVBS
20:08:36 Tuner IC: STB6100
20:08:36 Frontend/demod IC: STV090X (cut 3.0)
20:08:36 Current stream mode: TS=1, GS=0
20:08:36 TBS STB6100/STV090X direct control used !
20:08:36 BBGain = 8 dB
20:08:36 Turbosight (SAA7160 based) BDA extension used !
20:08:36 + Turbosight BlindScan support with STV090X
20:08:36 + Turbosight IR control support
20:08:36 + Turbosight I2C access support
20:08:36 + Turbosight fast LNB control support
20:09:08 MISSel(0,0x00,0x00)
20:09:08 PLSSel(0,0x08)
20:09:21 MISSel(0,0x00,0x00)
20:09:21 PLSSel(0,0x08)
20:09:30 MISSel(0,0x00,0x00)
20:09:30 PLSSel(0,0x08)
20:09:50 MISSel(0,0x00,0x00)
20:09:50 PLSSel(0,0x08)
20:12:33 MISSel(0,0x00,0x00)
20:12:33 PLSSel(0,0x08)
20:18:09 MISSel(0,0x00,0x00)
20:18:09 PLSSel(0,0x01)
20:18:40 MISSel(0,0x00,0x00)
20:18:40 PLSSel(0,0x08)
20:18:49 MISSel(0,0x00,0x00)
20:18:49 PLSSel(0,0x08)
20:18:55 MISSel(0,0x00,0x00)
20:18:55 PLSSel(0,0x08)
20:18:56 MISSel(0,0x00,0x00)
20:18:56 PLSSel(0,0x08)
20:19:15 MISSel(0,0x00,0x00)
20:19:15 PLSSel(0,0x08)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Already joined Ricksat ..
Sadly unable to post straight away ..
Account has to be verified and checked first..
Ironically...I was able to send a PM straight away ..so PM Crazycat ...below is what I sent ...
And below that is a copy of the log from scan to input and activation of root8 ..
As you say Llew ..nothing after that..
rgds
VS
PM to Crazycat
Hi Crazycat ..I hope you don't mind me contacting you directly as I can't post to the forum atm.
I'm a member of satellites.co.uk and it was suggested I might Join up at Ricks ..so that I might be able to contact you directly.
I love your software by the way...its superb ..and the combination of this plus the TBS6925 is an excellent combination for persueing my DX hobby.
Up to now I have had no problems ..but Having discovered that your new PLS software was capable of resolving the data layers on transponders such as those on Mediaset Hotbird 13 East 11432V ..I was fascinated and eager to try it out ..
Sadly I can't get the TBS6925 to lock and resolve those data streams ..
I have sufficient signal levels on my 1.2 Gibby ..and if I set 'root 8' ..the consellation resolves clearly showing it to be 8psk ...but no lock achieved ..no SR or fec etc ..thus I can't analyse the stream.
I'm using the latest version of your software 1.0.1.56
and the latest streamreader dll ...the required lib files ..and the latest TBS card driver StreamReaderExEx-BDA
But I'm still using XPpro..
is there an issue with XPpro ..or do I simply have a TBS6925 incapable of working with PLS.
I believe it is a version 2 card ..and I'm attaching a smal clip from the streamreader log which might provide a clue.
I simply can't understand what I'm doing wrong ..as in every other respect the 6925 an Crazyscan work perfectly well together.
Any assistance you can give me would be most appreciate ..
If you wish to check on the progress of others using your software ..I'm sure you'd be most welcome at satellites.co.uk
my second home ;)
rgds
Vipersan
22:49:09 StopDVB()
Extract of Crazyscanlog
21:08:42 StreamReaderEx BDA Ver:1.1.0.1046-commited (Oct 15 2012, 17:03:22)
21:08:42 Log level = 1
21:08:42 DLL_PROCESS_ATTACH hModule = 00480000
21:08:42 CheckForDVBEx(0x00407B00)
21:08:42 PID filtering disabled !
21:08:42 Power-off LNB on exit: ENABLED
21:08:42 SendDiSEqC use 2 repeats
21:08:42 Default modulation: AUTO
21:08:42 Default spectral inversion: AUTO
21:08:42 Default pilot: AUTO
21:08:42 Default rolloff: AUTO
21:08:42 Preffered BDA device type: AUTO
21:08:42 Available BDA-devices:
21:08:42 Device 0
21:08:42 Name: TBS 6925 DVBS/S2 Tuner
21:08:42 Type: DVB-S/S2
21:08:42 StartDVBEx(-1)
21:08:42 Device_ID: 0
21:08:42 Use Device 0
21:08:42 Tuner filter: TBS 6925 DVBS/S2 Tuner
21:08:42 Capture filter: TBS 6925 BDA Digital Capture DVBS
21:08:42 Tuner IC: STB6100
21:08:42 Frontend/demod IC: STV090X (cut 3.0)
21:08:42 Current stream mode: TS=1, GS=0
21:08:43 TBS STB6100/STV090X direct control used !
21:08:43 BBGain = 8 dB
21:08:43 Turbosight (SAA7160 based) BDA extension used !
21:08:43 + Turbosight BlindScan support with STV090X
21:08:43 + Turbosight IR control support
21:08:43 + Turbosight I2C access support
21:08:43 + Turbosight fast LNB control support
21:09:40 MISSel(0,0x00,0x00)
21:09:40 PLSSel(0,0x08)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
..Just got a reply from Crazycat over at Ricks ...to my PM ..
He suggests a problem with SNR ...but I can't send him the snr for this transponder as it requires to lock before such info is displayed.
What I have sent him is the info of an adjacent locked transponder 11393 V 27500
which returns
RF level -51dbm
SNR 14.9db
BER zero
the peak of which on the scan graph is about the same height and width as 11432V
rgds
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Welcome Crazycat ..
I do appreciate you joining the discussion ..
rgds
Vipersan
My SNR is 14.7dB on 11432V and 15.1dB on 11393V. Not much difference there, shouldn't be much less for you on 11432V.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Another image showing before Root8 applied to constellation ..and after..
Still no sign of a lock ..but certainly strong enough signal wise I think.
rgds
VS
Here with T-90 and old crappy LNB no problem with locking & viewing 11432V with 13.2 dB. Neighbour 11393V is 13.6 dB.
Edit: attachment added. Actually now I have sometimes freezes of the picture. Watch the BER, am I on the edge?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Another question ...a bit off topic for Crazycat ..
I notice on the 'search standard' drop down box there appears to be an option for DCII ..
which I assume to be digicypher ..
Can the TBScard resolve DCII ?
I can't access many channels of this type ..but maybe a couple in Cband ..
I haven't tried it yet ..but am interested to know if fta DCII can be resolved.
rgds
VS
