welshman234 said:
The reports I have seen from people in Vienna Austria dont look good...... be prepared for a bit of disappointment
that could turn into a big worry... if people here in Germany are picking the beam up with over 10 dB as far east as Berlin but nothing gets through in eastern Austria (Vienna), then that indicates that there is a very sharp signal drop-off on the edge of the beam. As has been feared.
Take a look again at the map:
_http://www.astra2d.com/images/astra1n/astra1n-satbeams.jpg
Whether or not the beam on that map is accurate, now that we have actual signal strength readings as of this afternoon from people across Central Europe, and keeping in mind that Berlin and Vienna aren't that far apart in terms of dish size region as indicated by the map, Vienna is only about 200 kms east of the outermost "half-circle" which coincidentally runs right through Berlin on the above map.
I'm not tech savvy enough to have any kind of idea how they are going to adjust the beam to focus more on Britain (if SES are indeed still going to work on that), but if they move the beam just a bit more to the Northwest and it really has a sharp edge like that, it might be that much of continental Europe will lose the signal altogether.
