Astra 28e in Israel [Astra 2A moves]
geoffrey
Zichron Yaacov
2.4M ChannelMaster Offset with Smart Titanium TQS LNB. LG SMART TV with SuperTrack V-Box 2 on ChannelMaster 1.2M Offset. TBS5925 tuner with EBSPro on Windows 10 laptop. Satlook Digital NIT.
Israel
This morning there is nothing from 28e on my 1.8m dish. Has the inevitable finally happened?
Mod note: Geoffrey actually meant his 2.4m dish.
Retired moderator
Vu+ Duo 4K SE
Dr.HD F15
Oooh Pooh sticks. Something has happened overnight to Astra 2A. Only got back to Helsinki last night so managed to watch Sky for a few hours before the big switch off...
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
no change here.
only 12304H weaker (Q58-70)
all others Q69-75
Retired moderator
Vu+ Duo 4K SE
Dr.HD F15
I'm guessing they've gone to the 2E or 2F Europe beam. Certainly nothing lockable in the old 2A transponder range now here in Helsinki on my 80cm (most signals are about 1-2dB ). Will check the 1.8m dish at my parent's house later, but that should be OK but with signal levels down a bit from before the move.
geoffrey
Zichron Yaacov
Israel
I meant 2.4m dish (is there no way to edit posts ?)
Retired human
There is but you only get a certain amount of time before the post is locked for editing (1 hour, I believe).
Retired human
Oh dear... Is that the end of Sky for you in Helsinki?
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
edit! will check again.. :wacko:
Retired moderator
Vu+ Duo 4K SE
Dr.HD F15
Here's this morning's view of 28E with my 85cm dish... :mad:
Only Eutelsat 28A left (for decent 24 hour reception) for the time being.
Retired moderator
Vu+ Duo 4K SE
Dr.HD F15
Still hanging on to Eutelsat 28A. ;) Oh and a few hours of a couple of lower frequency 2E Europe transponders. So as long as I have some kind of signal to lock on to I can still use on demand.
Retired moderator
Vu+ Duo 4K SE
Dr.HD F15
Just realised this thread was in the Freesat forum so moved it over to the fringe forum considering the topic.
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
4wd
Getting the picture
5 W, 9-13-19-28 E
Watching fascinating fighter stuff on Forces 12304H. Signal changed but still very strong, Q down from usual 96% to 91% on the receiver gauge.
Pride Of Cucamonga
Valencia (city)
Yep, formerly weak 2A north beam transponders coming in strong now. Interesting that Sky haven't switched their transponders to UK beam (as many suggest possible, but no actual proof).
11880 h have becon low
it still up signal
popolon
south west of Finland
Teleste 5m,invacom quad (28.2E), invacom quattro (26.0E). Triax multiswitch (1in, 8 out)
-TT 1600 PCI. Prof 3701 PCI.
-DR HD F15
-Ariva ferguson A120
Aerial 3m dish (7W-28.5E) + motor+ invacom quad.
-Ariva ferguson A220.
Finland
Retired moderator
Vu+ Duo 4K SE
Dr.HD F15
Here's the this evening's view from the 1.8m in Helsinki. All ex-2A transponders are lockable but the higher frequencies are getting a little close to the edge. This was taken when signals from 2E tend to be near the weakest during the day (stronger time are in the morning and late night).
photo 11720h
4wd
Getting the picture
5 W, 9-13-19-28 E
