ebuygum
- Feb 27, 2013
- Technomate TM-5500 CI Plus, 1.35m dish.
- Lanzarote
I have a Slingbox connected to a Humax HDR in the UK and a SlingCatcher connected to the TV in Lanzarote. The SlingCatcher has its own remote which controls the HDR. The delay is about 7 seconds.Yes you can but apparently the remote control part Is slow to respond and In an ideal world you would need a sling box connected to a freesat or freeview dvr to series record etc and then a good media player to connect to your tv abroad and again the remote control is not great as you would need to use another device like a wireless mouse or something ! Very messy !
If you could just have a normal dvr with a normal remote control under your normal tv then It would be much easier ! + you would have the benefit of streaming to tablets etc in other rooms as a bonus!
Also, as an added advantage, you can watch the HDR's embedded iPlayer and ITVPlayer via Sling.
Unfortunately they don't make SlingCatchers any more but I believe WD makes something similar that includes the SlingPlayer app.
