Astra 2F: European Beam Transfers Starting?
for receiver exmpel 28.2e or 28.5e need to move dish 0.5e not same posision for me
only 3.5m and up
stilobox
3 mt dish
lnb invacom dual out + feed horn
dm 8000
italy
This morning, In Potenza (Southern Italy), with a Prodelin prime focus dish 11Ft (3.34 m) I am able to receive all satellites at 28E. Starting from the best position for Astra2F (11023 H, 8,8 dB ) I had to route the dish towards West to catch the maximum signal at 12480V . Doing so I passed the best position for Astra1N, The variation for 12480V was from 9.5 dB (position Astra2F) and 10.2 dB (Astra1N) to 13.0 dB (best position for 1240V). So I can affirm that 12480V is not on either Astra2F or Astra1N.
Coviello
im agree with you Coviello.
in our fringe area i need to move my 3.00 mt dish for best results from astra 28.
at the moment i can receive all the frequency from astra 2a north beam...
in the past, i received only the high range frequency during the day and the low frequency in the late afternoon
rgds
stilobox
davidcmadrid
40cm offset 19e, 1.5m 28e 1.2 M motor vu+
Madrid Spain
Anybody any closer to figuring out what beam 12207V is on ?
@davidcmadrid
did you receiver 1.2m in mardrid to see 28.2e ?
What SNR are you getting compared to 1N spot?
davidcmadrid
Madrid Spain
Hi Solly,
If you refer to 12207V Madrid on my 1.2m motorized , i get SNR 74% which is a lot stronger than I get 2A north and weaker than 2A south. Its about right for 2F uk Spot but reports are its available in Portugal, its also much weaher than any 1N spot im aware of.
davidcmadrid
Madrid Spain
1N PE beam is SNR 100%
By " spot " if you refer to the what is being called the UK Spot , eg ITV3 10906V im currently getting 96% in heavy rain. Though to make sure were talking about the same " spot " this isnt really a UK spot right ?
kota
VU+ Solo2,Humax HDCI2000,Astra2 1.80m Famaval dish/Inverto Black Pro,Astra1&Hotbird 90cm dual lnb dish,Astra3 1.20m dish,Intelsat 907 80cm dish, Hispasat 60cm dish.
Sintra - Portugal
KOS has finally updated it's Astra 28º listings ... I reckon it's spot on
Istanbul, Turkey
What do you mean with KOS?
M60
Northern England
King Of Sat - _www.kingofsat.net
I've done some checks on field strength here in North West England and the PE beam of 1N (if that's what it is) certainly isn't at the same level as that of the spot. Even considering the wider antenna pattern, 1N and 2F have higher EiRP than 2A and 2B but looks like they are running the PE beam at lower power, ie the same as what 2A and 2B was/is.
Can anyone with Crazyscan analyser software do some off-air plots to reference.
ant21
I have a Xtrend ET 6500.
My dish is a Wave Frontier T90 and I make reception from 42 east to 1 west.
I use 14 lnbs with diseqc 16x1 emp.
Noerthwest of Greece.
According to a report in Greece, in Xanthi North East of Greece (Lat:41 Long.25) Astra 1N European beam is NOT receivable even with 1.2m dish.
This is very strange due to the fact that according to the map, this beam should have been there OK with 1.2m.
In general it can be argued that the signal drops dramatically at the edge of the beams of the new satellites of SES.
Therefore, in Greece we will not have chances to receive channels (when this happens) from the Astra 1F European beam with dishes less than 1.5m.
Retired Mod
www.timo.me.uk
Xanthi looks like it's right on the edge of the 1.2m border. If you can't pick it up there with a 1.2m then it's not surprising I can't get it with a 1.8m in Helsinki. In your case the 2F European beam would make more sense.
oldfart
laminas 2.7 offset
Invacom Quattro LNB
Chayofa, Tenerife
DM8K
Tenerife
post #183
http://www.satellites.co.uk/forums/topic/156865-astra-2f-canaries-africa-discussion/page-7
davidcmadrid
Madrid Spain
What is the point of a beam that requires a 1.2m dish in any case .. The only people that have dishes that big are enthusiasts anyway ? I dont think the mass market is going to be putting up 1.2m dishes anytime soon.
Retired Mod
www.timo.me.uk
1.5m and 1.8m dishes are still quite common in Finland and where pretty standard in the 90s if you wanted to watch satellite TV (eg Filmnet) before Canal Digital and Viasat came along and the higher power Astra and Hotbird satellites. My parent's neighbourhood in Helsinki isn't cabled so virtually every third house or block of flats had a 1.8m dish in the garden or on the roof looking at Astra 1A/1B/1C, and there are still a lot left.
C0re
Specialist contributor
Ede
VU+ Solo SE
Gelderland, The Netherlands
According to Lyngsat there are only two transponders still active on the Astra 2B, both south beam: 11973V and 12344H.
M60
Northern England
That's got Sky Sports 4 HD, Sky Atlantic HD and Sky 1 HD on it.
C0re
Ede
VU+ Solo SE
And Sony Entertainment TV (SET).
i hope it move last two tp from 2a move to 2a south beam
welshman234
sky hd uk, 80cm kathrein dish,vu+ solo, humax f1 fox for hotbird 13
frankfurt
tttses.com/7543799/SES_fleet_map.pdf Re -reading this document 2B is destined for 19.2°- dunno if this has any bearing on whhat theyre doing. just reread this thread and this has already been pointed out sorry!!!!!!!!!!!!!!
