Best lnb for sky mini dish
Icemen786
Sky uk
West Midlands
The lnb has arrived and as i said the labgear and the visiblewave look the same, confirmed they are the same as came in labgear box but on the lnb has visiblewave inprinted on it. Also i did say its a 40mm as per the description on the amazon add.
My old 40mm adapter has worked but it was that weather worn that it has cracked still holds the lnb but will have to look to either get another 40mm adapter, any1 know where i can get one? Or will try get a mark 4 arm which is a little thinner will work with the adaptor that came with it.
Lets see how it performs in the rain, if not glitch then job well done for 15 quid.
Is it not possible to glue it? I may have a spare mk2 holder but it too will be badly weathered.
Will this work? Its 37mm but if i use top of the clip that came with the lnb might work?
Good old-fashioned nylon cable ties could a quick and decent "solution" - and easily "reversible" if a more permanent solution is found. :D
Icemen786
Sky uk
West Midlands
It's the other side from the screw. The swing arm. I might try some super glue. If u can have a look 4 me pls. Is it 40mm ?
It will be 40mm - it came with the dish and had extra plastic bits to limit the skew but I ground them off so universal LNBs could fit.
Icemen786
Sky uk
West Midlands
Its raining and im not getting glitching which is plus side
Based on the pictures in this post
you are doing well.
There are adapters for the early dishes from certain outlets, but they would be more expensive than a new dish - delivered - from better suppliers, which the Labgear stuff slots straight onto.
A half-round metal rasp-type file would be pretty good for quickly removing the ridges in the LNB clamp to enlarge the internal diameter (I think I may have done that at some time in the past).
The internal diameter was 40mm to begin with, I used a Dremel type tool with a small grinding stone to remove the bumps that slotted into the guides on the LNB.
Icemen786
Sky uk
West Midlands
Update,
Still getting glitching on some asian channels. Even when the weather is clear. Looking at the signal it show 85% then drops to zero flicking betwen zero and back up which is causing the glitch.
Next thing now im going to change the cable to webro wf100 twin cable, see if that helps. Might be a damaged cable.
Gladstones
Zone 2 Fixed at Astra 2
Gibertini XP 75 cm fixed at 30 west
Gibertini XP 1 meter motorised 53e to 27.5w
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Update,
Yes it can be cable and loose f connector Did you check the alignment of the dish
Icemen786
Sky uk
West Midlands
No not checked alignment yet. Is there a good alignment cheaper thats not that expensive?
Something like this:
https://www.amazon.co.uk/Satellite-Finder-Signal-Meter-Patch/dp/B002R5UP1A/
It might be too much signal .....
Icemen786
Sky uk
West Midlands
Too much signal? Can there be such a thing?
It was twin cable so i swapped the cable from my sat box with the one that was going into my tv and its stopped glitching. Must be loose connection or cable what you recon?
Yes you can overload the tuner with too much signal, but as you've demonstrated it looks like the cable is the problem.
Icemen786
Sky uk
West Midlands
Just ordered some webro wf100 cable. Will the genuine cable have webro wf100 on the outside?
Which are the best f connectors or will screwfix one be ok?
Webro is Webro
Icemen786
Sky uk
West Midlands
I get that but what i meant was will I be able to determine if its fake cable?
Also will these f connectors do the job?
