Es’hail 2 25.5e
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
I purchased this LNB for 10.10.7 and I have a question will it work with diseqc and how to setup the receiver setting - to 9750 or ? Thanks !
Also want to know this ! Come on guys help out a newbie please !
DiSEqC has no affect on the incoming signal of the LNB to the receiver except to switch between one component and another (DiSEqC 1.0/1.1), or to move a dish with the correct motor (DiSEqC1.2/1.3)
The different incoming band is a simple case of subtracting the new local oscillator number from the received total, though by scanning with a blind search, you should get what is being transmitted in the channel list.
stephan94
Bavaria
Today found an Active Frequency in the field of radio amateur.
it is with a SR of 500 and there is a picture.
Picture is of course not optimal but at least you can see the radio amateur.
25°5E_1903281601.jpg25°5E_1903281601_10480-10530 H.jpg25°5E_10496_H.jpg25°5E_10496_H_5944.jpg
stephan94
Bavaria
better and better
a video with a sr of 333
If the symbol rates get lower they might have to go black and white.
stephan94
Bavaria
10496,5 H 1000
sr 1000 DVB-S2 QPSK2 2/3
PE1ASH MIJDRECHT
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
TBS 5590
No chance, no CS support. There`s no chance to find out the scanning range. No scanning program supports it, yet.
This card deserves support as it can show so much!
TBS 5925
Start scanning frequency is from 10550.
TBS 6983
OK
TBS 6903
OK
TBS 6903x
OK, but there`s no CS support and because of that a false frequency appears.
BUT LOCKED after manually given all necessary parameters.
TBS 5927
OK
TBS 5520SE
OK, but it doesn`t show all necessary parameters. Lack of support - no blind scan support yet.
Prof 7301
No chance.
How are you getting CS to show below 10.7 ? I am lost !
stephan94
Bavaria
A "video" with SR even lower.
This time sr 250
dwabbit
zgemma x2 plus 2x 1m dishes and 1 80cm dish for eshail 2 for ham radio
lincolnshire
the lowest sr is 33ks
stephan94
Bavaria
stephan94
Bavaria
This morning two feeds found G4GUO and G8GTZ
stephan94
Bavaria
This evening with SR 250 is the picture quality
not that bad
Here by radio amateur G7JTT
SatSearcher
West Yorkshire
Could some kind person explain how we get CS to scan below 10700? I think me and quite a few others are having difficulty getting it to do this! I've already tried all the above mentioned changes to the streamreader & crazyscan ini's, none of them work for me! I'm using a TBS6903, which I believe is capable of scanning this low. Thanks in advance!
SatSearcher
West Yorkshire
Thanks for the reply, but still doesn't work! When I enter a frequency below 10700, eg 10450, it just changes itself back to 10700. Tried with IQ Monitor too, it lets me enter a scan range of 10400 to 10700, but just get a flatline scan.
You don't need to change anything in CS ini. What are your start and end frequencies in your Interval tab in CS?
SatSearcher
West Yorkshire
I try to get it to scan 10400 to 10700, but when i enter 10400 (or anything below 10700) it just resets itself to 10700. It just refuses to let me enter anything lower!
I have a version of CS that's just set up for Es’hail 2 25.5e - i tweeked CS .ini just for the hell of it to use just the bit of frequency span for the satellite but as Llew said you don't have to do that.
Your streamreader .ini for the version of CS you are using needs to look exactly like the picture, and is what Llew and others have eluded to in previous posts. Edit the lines and then 'save' when it prompts you apon exiting. This works for me ok.
SatSearcher
West Yorkshire
Thanks John, but still no go. I have everything edited as shown but i just get this when starting CS:
Am I missing something obvious here?
