Start time : UTC 2016-06-06 17:42:10
End time : UTC 2016-06-06 18:04:33
Overall bit rate mode : Variable
Overall bit rate : 4 273 Kbps
Network name : F
Country : FRA
Timezone : +02:00:00
Video
Menu ID : 769 (0x301)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : 27
Duration : 22mn 21s
Bit rate : 3 739 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.072
Stream size : 598 MiB (87%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : E-AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : 6
Duration : 22mn 22s
Bit rate mode : Constant
Bit rate : 96.0 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : -1s 164ms
Stream size : 15.4 MiB (2%)
Language : French
Audio #2
Format : E-AC-3
Codec ID : 6
Duration : 22mn 22s
Language : qaa
Audio #3
Format : E-AC-3
Codec ID : 6
Duration : 22mn 22s
Bit rate : 128 Kbps
Stream size : 20.5 MiB (3%)
Language : qad
descriptor_tag_extension : 6
