Rick said:
I get the feeling your not reading the guides, and taking short cuts will not help matters because you will miss vital steps.
It could just be the angle of the photo's but check the dish is central on the motor shaft, there is a casting spline on most you can use. Why do you want to send the motor to 0 ? If you setup as you propose it still won't work, you will be out by several degrees.
Sir,
I wish to send the motor to zero becuase i am moving the set up from an old set up, so im presuming it all has to be reset?
Send to zero, then line it all up with 1w. On the guides it says set it to ZERO then find 1w.
should i scrap the ZERO thinking?
I need a list of things to do when i go out there tomorrow morning.
Firstly I shall check the dish is centreal on the motor shaft. If it is I will then move the dish/motor to 1w.
I have just realised....Ive obviously been moving the whole Dish/Motor to find 28e earlier...that is clearly wrong becuase you have to find 1w moving the whole dish/motor then the USALs will move only the dish(not the motor) to go and find 28e...right? Sorry for my poor lingo, im rushing here, if you understand please spread some love and give a little tip.
cheers
