I have european beam but not UK beam ?
smartcombo
VU + Zero 4K+ Offset 1.25m Motorised Dish with Vbox III Iberosat + Motor Actuator 36v and Lnb Invacom. Satellites - 28E, 42E, 13E, 19E, 26E, 7W, 30W etc..
Portugal
lazzaro
Vu+ Du 4K
Europe
It is not necessary. I use OpenPli on Vu+ Duo 4K.
smartcombo
Portugal
I have already configured the satellites in the box and placed the ci+ cam. What do I have to do next
smartcombo
Portugal
I've already activated the cam but I can't view the channels. What could it be? Does anyone have a solution to solve the problem.
Upload some screenshots of the scanned in Kabelo channels and anything in the menus that shows the CAM is inserted and activated.
smartcombo
Portugal
I forgot to mention that I have a Uclan D-Box 4K CI+ Combo. I activated the cam on the kabelio website
smartcombo
Portugal
I don't see anything in the menu that says the cam is inserted
smartcombo
Portugal
lazzaro
Vu+ Du 4K
Europe
Enter Common Interface menu (the last photo) and upload it as well.
smartcombo
Portugal
lazzaro
Vu+ Du 4K
Europe
This is not right. You should see "Kabelio" in the Common Interface menu. I see it on my receiver.
It could be a receiver issue.
smartcombo
Portugal
then. So what if I unplug the box and plug it back in?
smartcombo
Portugal
It already appeared saying slot1 kabelio
smartcombo
Portugal
lazzaro
Vu+ Du 4K
Europe
Go to a Kabelio channel. What message comes to the screen?
smartcombo
Portugal
Now I can remove the cam that is on UCLAN and put it on zero 4k
smartcombo
Portugal
Can I put Vhannibal's list in the box even with the cam inserted?
jhalliday45
Setting up still bought a 125 dish for France and planning to use old Sky HD for Freesat
Cazeres
as Clarkson says 'Sit-rep!' - so months/ years or repeatedly trying to et things correctly aligned to be able to get channel4-7 and Yesterday, Dave, Drama etc - the only channels that never worked for me, all of a sudden this weekend I found them all working to a greater or lesser degree - signal quality was next to 0% but they worked.
SO what's changed ? has the dish moved ever so slightly in wind etc ? has the signal strength got stronger ? or is it just the clear winter skies ? - I assume the latter.
Am very happy they're working and ant to tweak it juts a little more to see if I can improve but each time I do that I make things much worse so lesson learnt will leave it alone.
