I have european beam but not UK beam ?
smartcombo
VU + Zero 4K+ Offset 1.25m Motorised Dish with Vbox III Iberosat + Motor Actuator 36v and Lnb Invacom. Satellites - 28E, 42E, 13E, 19E, 26E, 7W, 30W etc..
Portugal
smartcombo
Portugal
smartcombo
Portugal
Sorry, I don't understand this. What do you mean?
The box and the ci+ cam have arrived and I would like to know the following: I have to configure the satellites in the box
Mickha
North West
I've only found one video, so far:
smartcombo
Portugal
I already received the box. I would like to know if it is necessary to configure the satellites
Mickha
North West
The video shows you, towards the end, how to configure your satellites.
It's not a plug, and play, receiver, you need to configure, your options, and preferences, via the menu.
I haven't got one of these receivers, and can't find much, on the internet, regarding the menu settings, to provide a detailed setup guide.
I'm afraid it might be a matter of trial, and error, unless you can post pictures, of the menu, and provide more details, of your satellite set up.
Fixed, or motorized dish, one LNB, or multiple LNB's, with Diseqc switch, general location, or satellites you want, and can receive.
smartcombo
Portugal
I'm going to put the ci+ cam on my LG TV. What is the name of the entry where I insert the cam ci+
lazzaro
Vu+ Du 4K
Europe
There is only one hole which you can insert the cam. The name is Common Interface.
smartcombo
Portugal
This is what appears on my TV: PCMCIA card slot, will this be it?
smartcombo
Portugal
lazzaro
Vu+ Du 4K
Europe
Of course, your LG TV must also have a built-in satellite receiver, in order to receive the signal from Kabelio.
smartcombo
Portugal
It's not enough to just put the ci+ cam on the TV
smartcombo
Portugal
lazzaro
Vu+ Du 4K
Europe
Why don't you use the ci+ cam on uclan?
smartcombo
Portugal
