I’ve shifted the top bracket up slightly and have all three of those bolts in the brick, whereas for the bottom bracket only two are in the brick - I haven’t drilled the third one yet.
for the top bracket, the top right hole is slightly loose - I was able to push in the shield anchor without any force. When I tighten it, it does grip and doesn’t come forward. But should I use some resin in there to make it stronger?
edit: Now that I’ve tightened it, when I removed the bolt, the shield/sleeve has gripped the brick, I assume this is because it’s expanded.
These are the bolts I’m using btw
