So it's better to have the motor sitting above the top bracket rather than in between the two?
"It all depends" on, maybe,:
- how high you need the dish to be to get the desired arc?
- how high the top of the pole is?
- how far the brackets are apart?
- how easy or difficult you think adjustments of the dish declination and elevation will be with the motor & dish in
your chosen position?
TBH, it's about time for you stopped asking endless questions and
actually got around to "doing something" about getting the pole installed on some brackets, fitting the motor to the pole and the dish to the motor, and then finding out what actually works,
or does not,
for yourself - after that, then you will know what issues remain to be resolved, and what
few remaining questions you need to ask us for advice.
