I have been doing a little experimenting as one dose when one has nothing better to do:-).
My thinking is that if I moved north I would access the satellites farther north.Might even get the north pole. First I moved lock stock and barrel to Reykjavik 64.1265N 21.8174 W better but not enough.A quick flit to NUUK Greenland 64.1814 N 51.6941 W.a bit better I get Canada from there.I might get a look at the north pole up the Norwegian coast.I looks like another quick flit.
Moved to Narvic 68.4385 N 17.4273 E this time Got some weather too.Not quite up to the north pole though.Ha well another flit farther north up to Nordkapp 71.1695N 25.7832E this time.I did not expect anything from there got a bit of weather.It I can get my antenna to the top of the Emley Moor Mast I could be knocking on Terryls door.Unless of course I am tolaly of my rocker and gone doolally.
Most of the Greenland passes are too far West.The Reykjavik West passes get as far as Canada.A lot of the Nordnapp passes are too far East Weather is possible with the near zero ones.
This is a bit disjointed because I am writing it as I go along.
the NUUK one is from last night 9.15pm
Waiting for a NOAA 19 pas at Ittoqqortoormiit northern Greenland 70.4856 N -21.9628 at14:53 7 West of there If I get signal I should see farther north.
Ther yellow cross marks the spot.
