OCTAGON SX88 H.265 HEVC HD
stephan94
Bavaria
- ability to change channels from the list, I have to do it on decoder first!;
I don't understand the question .
What list? Favorit?
be more specific, what's the problem?
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
I mean:
When I choose with my smartphone a channel that is already ON on the decoder, everything is ok.
BUT if a choose a channel on another frequency or simply a different one, the smartphone/pc can't load it and the decoder shows this new channel with a black screen too. I noticed that the previous channel has a green square on it as it is keeping on streaming by DNLA.
If I RE-select the previous channel, It starts working again....
Pierangelo
stephan94
Bavaria
OK! Everything is related to DLNA.
I can't answer that kind of question.
I don't mind DLNA.
sorry
I don't have a smartphone
for me reception satellite is primordial occupation
and it is the party has ameliorate first and foremost when there are problems.
you can note at Octagon.
stephan
Tommybalbo
antenna 100 cm motorizzata ckarke tech 4100 - octagon sx88 . 57 est - 30 w
Italia
@ Tururu
I understand your problem.
It's true that with a relatively small antenna during the blindscan you can find
the frequencies of adjacent satellites.
The Sx88 can do than a full Blindscan, without possibility to limit the search (do not forget that it is a receiver for only € 75)
however we can't go satellites. xml (this receiver is not E2; Fortunately, because he would not likely still have BS)
it takes just to early to do his own frequency list and then put it on a USB memory
Without a program like making a list at will and plugging in via USB memory?
Mod. Note. Quotes fixed
stephan94
Bavaria
octagon_sx88_v1.04.27_20171025_EU NEW SW - 25 10 2017
SW Update: Menu - Settings - SW Firmware Update: USB - Red Button : OK
- added dreambox_editor(v7.2.0.0) support
- ftp user name: root, password: sky1122
- dbase folder in box - ftp : local/enigma_db ( /home/gx/local/enigma_db/ )
- added dvb fav group create, rename
- added dvb fav group channel list seperate order support
- fixed some stalker server has two portals will login wrong problem
Menu - Settings: PIN 6363 --> CAS Setting (Bottom)
FTP enable: Menu - Settings - Misc settings : FTP Server ON
FTP login: root , PW: sky1122
Download OCTAGON_SX88_SW_EU_V10427_251017.rar (29.58 MB) now. Fast and easy at workupload.com
Tommybalbo
Italia
Tommybalbo
Italia
Great thanks
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
Tried new firmware above.
I had a quick look at the editor on my pc. The program connected to the receiver without problem.
I am having a problem allocating satellites positions on the the positioner. I will have another look at this tomorrow.
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
It seems that when saving a satellite position on a 1.2 positioner the new firmware wants to save every satellite at position 01 on the positioner!
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
It is good to see enigma2 type files for the channels, settings, and satellites. I can get these files from the SX88 and transfer them to my computer using ftp. But I cannot send these files back to the box through ftp and have the SX88 recognize them or use them. The SX88 always defaults back to the unedited files after reboot.
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
I could not save satellites to any other position than position 01 on positioner. Reverted to former firmware and now have satellite database for the whole world!
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
Now loaded my saved channel database and back where I started, fortunately! I will wait for the next update before trying again.
stephan94
Bavaria
Now the possibility to do an online update directly by Internet. online update Sx88.jpg
stephan94
Bavaria
For people used to Enigma2,
Now the SX88 also has data satellite.xml
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
That is a nice picture. But like I said back in post #380, I cannot alter the satellites.xml file or any other file and have the box save it. So that feature is pretty useless to me right now.
MCelliotG
Thessaloniki, Greece
Maybe if you could telnet to this receiver and use init4 command?
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
I wish!
init 4, init 3...etc is not supported. Maybe later?
I did manage to get a satellite list for North America installed using the editor in Windows.
MCelliotG
So, it does allow changes somehow. How did you activate the changed satellites.xml, factory reset?
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
I used DreamboxEdit to transfer the satellites.xml file.
I used telnet to restart the box after transferring the satellites.xml file. The telnet command I used was "reboot".
Laser
online-update-sx88-jpg.111224
So Stephan how do we access these please for internet updates. Thank you.
