OK, step-by-stepI've not done any of this before
Thanks Rima.OK, step-by-step
- download DCC on your PC and connect to your Enigma2 box;
- go to FTP tab and copy to PC file named settings from etc/enigma2 folder (green underlined). View attachment 133506
Open DCC again and in the same file replace all lines starting config.nims (in red block) with previously save to PC.
- go to telnet tab in DCC View attachment 133507 , enter killall -9 enigma2 and klick Enter. Box will reboot with new settings.
Yes, restart the box on blank image (Open PLI in your case) and replace only config.nims lines then killall -9 enigma2Do I now restart my receiver on the image (Open PLI) I want to copy over the settings to & then replace the lines you have marked in red ?
I can connect to the receiver, view & edit the settings file but when I enter killall -9 enigma2 in telnet tab nothing happens ?Yes, restart the box on blank image (Open PLI in your case) and replace only config.nims lines then killall -9 enigma2
Thanks Rima.Enter killall -9 enigma2 command with 2 spaces in the middle and no additional space at the end (after enigma2).
That's a pity as I've good things about that image ?The genuine Open Black Hole images are only for VU+ receivers.
SD Card Partition ?Forget the Vix Image manager...
Switch the SF8008 off at the back, hold the standby button on the receiver , whilst doing that switch on the power button until 'Update' appears on the receiver display wait a minute or so for the menu below to appear on the TV screen the scroll down to 'Network Multiboot Image Upgrade',View attachment 133479 press OK , select what image you want on what slot and off you go. You can also boot the receiver to whatever image you choose from this menu
Yes, a total of 6 slots are available then..SD Card Partition ?
I have installed an SD Card of 16Gb.
Can I partition it with SD Card partition to create extra image slots or what is its function ?
Tony.
I have a USB key in the rear USB slot.Yes, a total of 6 slots are available then..
I'm pretty sure formatting an SD card will give you 2 extra slots, not 4..I have a USB key in the rear USB slot.
I have four images in the slots. If I format the Sd card will I have four more slots?
I didn't want to press the format button in case I did some damage.I'm pretty sure formatting an SD card will give you 2 extra slots, not 4..
You will be OK.I didn't want to press the format button in case I did some damage.
TonyI formatted the sd card which created two more slots as was suggested by scopus. The only way to access the images on the sd card seems to be using the on / off button at the back in combination with holding down the power button on the front.
I think at this stage I've had a look as most of the images available from the network.
So far VIX & OpenPLI seem the most interesting. In some of the images menu items can still show up in another language even if English is chosen at the start.
OpenPLI was the only image that would accept the DCC method of transferring my settings as suggested by Rima earlier without the need to set up the tuner for each individual satellite even though that's not really a problem.
Tony.
I think I have Satdream in one of the slots.Tony
Yes, that is correct. The multiboot option on the images only shows the 4 images to select. I think the the SX88 firmware will show them all when you select multiboot.
My favourite two images are Vix and Satdream.
