I'm not sure why you'd be trying to add 37.5w when it should already be in the satellite list?
The reason why you may not be getting answers is because the vast majority of sx88+ users will be using it with a DiSEqC 1.3 motor with USALS, and not a GBOX shared between 2 receivers, which is a fairly unique setup. Do the satellites you've set up work and move the dish automatically, and do they still work on the Technomate?
When I booted up the SX88+ I found that 37.5W had been saved but if there are no channels saved on a satellite in the SX88+ it won't be seen when you press the Sat button on the remote ? You have to go into the menu/fav to find the satellite ?
The main information I was after was regarding the SX88+ menus & how to set the receiver up & I understand that most people wouldn't be using a GBOX & DiSEqC 1.2.
The satellites I have put in work fine & the dish moves to the right sat.
They still worked correctly in the TM7102HD when I checked it yesterday but I may have made a mistake storing the GBOX positions on the SX88+ as its one position ahead of where it should be & I don't know a way of changing it, just as I don't know of a way of skipping a position on the SX88+ ?
A few things I have come across which someone may be able to help me with ?
(1) On Intelsat 901 27.5 West I have 83% signal quality on the BBC transponder 11.499V but when I go to search the transponder the SX88+ finds nothing & the quality bar shows 0% quality ? When I exit the search the quality bar shows 0% but if I go the another transponder & then back to the BBC transponder it again shows a strong signal.
Edit: I just switched to the TM7102HD & it brings in the BBC channels ok.
I also found that the quality could be improved using the TM7102HD to peak the dish. Going back to the SX88+ I found that the quality was now 100% but it still didn't find anything ?
(2) When adding a transponder the 3rd & 4th settings down are NIT & MTS ?
What do NIT & MTS mean ?
(3) In transponder search you have "Renew channel Data" ?
What does this mean ?
(4) How do I do a blind search on a satellite please ?
Thanks everyone for your continued help.
I really am grateful.
Tony.
