Simplest Option For Dual Polarity Rx on Prodelin 1244 RxTx ?
Hi @moonbase.
Could you make some measurement of your support.
I have tried to make some similar but, i do not know how good are my estimation in reality.
Thank you.
The feed assembly and support system are now installed on the Prodelin 1244 dish which is mounted on a 2.2m high pole. It is not easy to get access to it for measuring.
If there is an opportunity in the future to take some measurements I will post them in this topic.
Prodelin are usually quite good with specification drawings, there might be something for the Ku-Band feed assembly online?
g host
Oltenia Land
Prodelin 1194 & 1244. TBS6925 TT S2-1600.
Thank you.
I only found measurements(A,B,C,D) in inch from feedhorn to top & bottom edges of dish.
Rgds.
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
Just wanted to share a very simple solution for TX-RX Prodelin’s feed holder issues
Cheers
That feed looks familiar, Echostar rx only from 20+ years ago, used to have a mechanical depolariser circuit on the rear.
pipino
Back from the dead
You mean this one ?
You mean this one ?
No, the actual binocular (three stage) feed you have , with cap.
I've seen it before without the mechanical gear section, was sure it was on an offset dish with Echostar branding.
But it was many years ago.
pipino
Back from the dead
it was part of a channel master kit if I remember well
