Vipersan
Emmett Browns Ghost
- Jun 29, 2009
- Age
- 66
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
- UK
Huevos said:VS, I don't really see where you are coming from. 17º isn't exactly low elevation and anyway 3º is 3º whatever the elevation. Also, on an 80cm dish 3º off target results in a signal around 20dB down. That means the signal coming from the central satellite is 100x stronger than that coming from the offset satellite. With a 5/6 FEC signal you need <8dB SNR for correctable reception leaving 12dB in reserve. That means for this effect to happen one signal needs to be at least 12dB stronger than the other... but that would mean you would have a 32dB margin in the other direction, i.e. almost 2000:1 SNR. I can see a strong signal on an adjacent satellite wiping out a weak one on the central satellite but it would not be possible for that to happen in both directions, at least not at 3º separation.
I can't argue with your logic Huevos ..
But I do know that the F15 has no problems with either of these 2 transponders on either sat when given the transponder settings ..
Nor does the TBS card ..
But ..if I ask either the F15 or the TBS to blind scan the 2 sats ..
The F15 always finds the 11012 transponder on Turksat ..but misses it out on Hellas2 ..
& the TBS using EBS ...misses out 11012 on both sats ..
So ...there _has_ to be a reason ..and so far ..thats the only one I can come up with..
If you have a better suggestion ...I'd be more than happy to accept it..
rgds
VS
