Telstar 12 Vantage.
Something was wrong, with the given parameters, the bitrate should have been almost 80 mbps.
I've no idea what they are filling the transponder with to give that result. There's nothing useful being transmitted that makes any sense to us, just a succession of pids changing in number and frequency over time.
hatters1976
Satellite dish: 1x 2.40, 1 wave frontier T90 (7e-46e). Octagon, gt media gt combo-v8x. Football and basketball feeeds enthusiast.
GR
In other forum it is said that telstar is using for this footprint of middle east too ? This info can be confirmed
by someone here living on that region? Forum says " footprint north sea and footprint middle east "
SatSearcher
West Yorkshire
Absolutely refuses to lock on my TBS6903, yet it looks like a perfectly normal DVB-S2 signal on CrazyScan. I see people with the 6903X can lock it, which would suggest it's actually using DVB-S2X, but my Octagon SF4008 also refuses to lock it, so I guess it's not that! When I've had problems like this with other signals it usually turns out to be a PLS code being used, but that's obviously not the case here either!
Locks OK on the GTMEDIA V8UHD..
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
can you make a TS capture and share it with us please
It won't download anything so unable to see any details. I will try the S3 Mini later, that should reveal something perhaps..
EnoSat
enosat.euweb.cz
Slovakia
If I'm not mistaken, these receivers record only Video-Audio (pids from PMT) of the given program in TS format, they do not record the content of the entire transponder.
pipino
Back from the dead
i dont know Gtmedia stb but on octagon its pretty simple
stb information, press stop button, red button to record
pipino
Back from the dead
On Octagon native OS you can record the full TP if not mistaken
Locking now with TBS6903. No useful pids yet. A realistic bitrate.
EnoSat
enosat.euweb.cz
Slovakia
Does the stream just generate random PIDs?
Not sure, with regular PCRs inserted. At the time of capture, largest is 0.13% of the stream. Some pids show 0.0% (?)
EnoSat
enosat.euweb.cz
Slovakia
yes, it simulates a full TS (8192 pids), but I don't know how it affects testing compared to using only one pid 8191
pipino
Back from the dead
May be active TP with no contens !?
EnoSat
enosat.euweb.cz
Slovakia
yes, all PIDs in TS are randomly generated
7mdish
Milan, Italy
...and how they can be decoded? Which receivers handle randomly generated PIDs?
7mdish
Milan, Italy
no way, no specific content is broadcast
So, if I understand correctly, we can't be sure this is the replacement for BBC Satback from 27.5W? Please correct if I'm wrong.
