Astra 2E: Western Europe Reports
stephend2017
KU Band: Motorised 1.2m dish connected to a TBS 6981
KA Band: Eutelsat KA-SAT 9e on Ireland spot beam connected to a TBS 6904
Ireland
You're contradicting yourself there. It's probably possible with very big dish (I bet no less than 3m).
From experience living there, everyone just uses IPTV. I know of a 3m and 3.2m dish failing to receive the UK beam so anything bigger would be a bit unrealistic. Maybe it is possible with a huge dish but I have not heard of any success so therefore I think it is not possible.
superpascu2
ATLAS HD100 - ASTRA 19,2 + HOTBIRD 13 + 28,2 1.2m famaval
Alicante
Another option is the satback, Intelsat 907 27,5W
stephend2017
Ireland
the frenchman
Thomson HD
Spain
It was only when I lost the ITV signal that I looked around on the internet and read about their reputation.This one has been fine for 3 years + so I must have been lucky.
Even luckier,while waiting for the more up to date Sky + box to arrive I was just flicking through the channels and even though up to that point there had been no more winds that might have moved the dish BBC channels were back.Maybe a Thomson box that healed itself.:) Even stranger Quest HD that is as clear as a bell on the Thomson,pixels on the new box??
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
Dears,
is 12129 V lower than usual?
espacially during late evening and night?
thanks
RimaNTSS
Some SAT-related hardware.
N-E from Riga
@Pierangelo I think this is very much depends on your location. Some time ago I have monitored another transponder from Astra 2E, and signal variations were ~2dB during the day. More or less the same is probably happening with 12129V. Enjoy fringe reception.
rodscha
i just checked and,yes ,at midday BST or 1pm CET,12129 is 40%
when PBS stands at 70% ,
BBC 1&2SD at 73%
but BBC HD falls behind watchability at 18%
so,yes,much weaker wihin the SD group
Then the weather is more seasonal greyish & colder,would that put propagation down somewhat?
S
Sleepingwiththefish
Dears,
thanks
Maybe a tiny bit, I have ~9dB, drops for me are generally around 0.5dB and less than 1dB (clear sky, uk beam).
12129V is DVB-S/QPSK/FEC 2/3 gives room for drops.
But the 12382 is 'fading' away, almost impossible to get here, if they would drop FEC to 2/3 or even 3/4 that would be the day!
Alistair_
Gibertini 1.5mt
Inverto Ultra
Amstrad DRX895
Pace2600
N. Italy, 40km E. Milan
Yes I'm also experiencing lower than usual reception.
4wd
Getting the picture
5 W, 9-13-19-28 E
Norway, lower levels (uk) than usual, losing more channels \ for longer period in the evenings.
But no problem, blaze (eu) 'forged in fire' shows up fine :O)
woborny
Dont forget we are in "eclipse" season, and so you may get some loss during the day during the biannual solar outage, and again later at night, when the satellites are in the earths shadow and on battery power....
rodscha
we hope the satellites ,when in the shade, carry Duracell... and the rabbits are well-fed!
Stevenvc19
3x Edision Primo S2:
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
12382H gives me 100% SQ in Belgium but the 12129V keeps dropping. I first thought my dish was slightly twisted. but it hasn't. two weeks ago I noticed the SQ dropping from 100% to 92%, last week I saw it drop to 90% and now i'm only getting 87%!
All the other transponders on Astra 2 give me 100%, even in bad weather...
I guess the reception of 12129V will recover to its full 100% in a couple of weeks, or could I be wrong?
S
Sleepingwiththefish
Signal figures in percentage are always merely indicative and most times unreliable, a receiver can show 30% signal and another one shows 70% for the same sat setup and transponder/channel.
stephan94
Bavaria
this is how I get ASTRA 2 (E, F, G) with a motorized antenna of 1.20 m from the north of Bavaria.
These results are dependent on the time at which these measurements are made.
location.jpg28°2E_1903080836_10700-12750 H.jpg28°2E_1903080836_10700-12750 V.jpg
wallycharlo
DM800 / 1m Gibertini XP
Western Austria
I've noticed a considerable signal drop on Astra 2E UK beam for about at least a week or so. E.g. BBC ONE & TWO HD are now breaking up in the evening, was fine before. We had strong winds recently I had thought that perhaps my dish had shifted, which sent me out into the cold last night trying to remedy the situation ...
Nalleman
Motala Sweden
Sweden
12 129 V has been weaker than usual for a couple of weeks at my place in southern parts of Sweden but since FEC is 2/3 - no problems. 12 382 H is hopeless to get due to FEC 5/6. Earlier this year it was pretty strong (being that transponder) but now it's completely gone.
Noticed that 12 304 H is in use again! Used to be on a UK beam of 2F and almost as weak as 12 382 H. Now it comes in very strong so it can't be on a UK beam this time around. Could it be that 2G or 2E (don't think 2E) has European transponder at 12 304 H?
4wd
Getting the picture
5 W, 9-13-19-28 E
At time of posting, 120cm in Norway, 12382 H 8.5 dB, lost in the evenings. 12304 H 16 dB, definitely EU.
Nalleman
Motala Sweden
Sweden
Reply to my own message. 12 304 H can't be on 2G since 2G European is much much stronger at my place.
So my guess is that it's on 2F based on the signal level which is weaker on 2F European than on 2E and 2G. Meaning 2F can do 12 304 H on both UK AND European beam but not on the same time of course. Very strange I must say.
RimaNTSS
N-E from Riga
Most of you guys living in UK probably do not see any changes in reception of channels from Astra2E (UK beam). But we, who have to enjoy fringe reception feel that something is going on with satellite. Firstly, the levels of signal are increased, and daily variations as well. I have recorded signal levels from 10714H for 24 hours (each 13 seconds) and from data built this graph. If you compare this graph to the same graphs which I made 2 years ago it is possible to see some similarities and maybe also tendencies.
